Hi,
My system seems to be running much hotter than I'd like and making more noise than ideal, so I'm looking for a big upgrade.
I can spend around £900 if needed, but would prefer less of course.
I don't know much about water cooling, but have built a fair few systems.
Current System:
Crossfire 6850s (run hot)
i7 2.7Ghz 1336
Corsair H-50
CM690 case
650w Corsair PSU, 80GB Intel X25-M ssd, 2x 1tb WD green drives, 2 monitors etc.
So, I'm thinking probably a new case, water cooling, and perhaps swap out my cards for a single 7970 as I can't find a GPU block for mine and would probably like to upgrade if I'm going to have to buy water blocks etc.
I would like the system to be able to handle another GPU if I crossfired the 6970's some day in the future without too much hassle.
So I drew up some "initial specs", but I don't know if it's any good.
Sapphire 7970 (£320)
Watercooled Haf-x (£315)
7970 Water block (£80)
Thermal Paste(£9)
Total: £738
I don't actually fully know if this will all connect together, or if I can get another block eventually for a second card. Or I could upgrade to the Corsair 800D also.
Or would you recommend building the whole thing myself?
I really don't know much about watercooling, in fact I was close to (and might still) asking OcUK if I can buy these parts and come down with my PC for a quick hand transferring (if they would do that I don't know).
Also, would I instantly lose my 7970 warrenty by putting the water cooling block on? Unless I buy this one already with a block but that's much more than the price of the card + block
Linky
Thanks
Current System:
i7 2.7Ghz 1336
Corsair H-50
CM690 case
Thermal Paste(£9)
Total: £738
Linky
Thanks
