Getting around to replacing my current home media server as it is showing its age when it comes to supporting larger drives.
The basic plan is to allow for the maximum amount of storage space in a reasonable sized case with the ability to add more in the future via a SATA PCIE card.
The rationale behind some of the decisions:
- The SSD's are for the OS in RAID 1 which will be housed in the 3.5" caddy.
- AMD CPU/Mobo is chosen because of the number of SATA 6Gb/s ports available when compared to a similar Intel build.
- Case is chosen as it has ample external bays for the 5 bay backplane with an extra spare. The 3.5" caddy will be placed in the floppy drive bay. Still leaving the internal sata bays available.
- Modular PSU to allow SATA power cables to be added if needed. Preferably looking for a more energy efficient one.
The OS itself will be Server 2008 R2 Standard and will be running software which wont be too system intensive. However this software is Windows only as I have not been able to find decent alternatives for open source.
So, what do you guys think? Any improvements you can suggest?
