** Ace Modder's Championship £25 Elite Mega Deals Thread **
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Hey Guys
A few sweet deals here that will allow you to qualify for a Dirt Showdown code :D
The OcUK PC Games weekend deals have been extended to allow you guys to get the most out of this deal
Check this thread for the PC Games Deals
Here are some great products that are around the £25 mark that will allow you to qualify :cool:
Some have been discounted to £25, some are around the £25 mark already
Get amongst it guys!
Grab a bargain today!
OcUK Imp MicroATX Tower Case (500w PSU) @ £25.00 inc VAT
Building a new PC? Then this is a great entry level case with a 500w PSU pre-fitted. The case is finished off with an all black interior to give a great look and feel.
- Dimensions (mm): 180mm x 360mm x 425mm (W x H x D)
- Body Material: 0.5mm, SGCC
- Front Bezel Material: Plastic
- Side Panel: Vented
- External Bays: 2 x 5.25” / 2 x 3.5”
- Internal Bays: 3 x 3.5” Internal
- Expansion Slots: 4 Full Size
- Cooling Front: None
- Cooling Top: None
- Cooling Rear: 1 x 80mm Fan
- Cooling Side: None
- Cooling Bottom: None
- IO Ports: 2 x USB 2.0
- 1 x HD Audio (Supports AC'97 Audio too)
- 1 x Microphone
- PSU Included: 500W with 120mm Fan
- Net Weight (KGs): 4.8 KGs
Was £28.99 Inc. VAT
Only £25.00 inc VAT.
ORDER NOW
Xigmatek Asgard Midi Tower Case - Black @ £25.00 inc VAT
The Asgard case is the first entry-level chassis with a black coated interior. Furthermore it is supplied with 1 x 120mm pre-installed black fan, and 3 more fans can be mounted in different area for best possible airflow. The 4 x 5.25" bays will be able to house all your optical drives and you can fit up to 5 x 3.5" bays for all the storage devices you need.
- Screw-less tooling for the bay device
- Dust filter behind front panel for intake airflow
- Dimensions: 185 x 475 x 408 mm (W x D x H)
- 4 x 5.25" Drive Bays
- 6 x 3.5" Drive Bays
- Front Cooling: 1 x 120mm black fan
- Rear Cooling: 1 x 80/90/120mm fan (optional)
- Side Cooling: 2 x 80/90/120mm fans (optional)
- Front I/O Ports: 2x USB2.0, 1 x HD Audio
Was £29.99 Inc. VAT
ORDER NOW
OcUK Swift 650W V2 Silent Power Supply @ £25.00 inc VAT
The OcUK Swift V2 Power Supply is sourced and built from high quality components making these reliable power supplies for anyone who is building a home or office computer. They feature a 120mm red fan for low noise operation keep the whole PC quiet. These units offer incredible value for money and are ideal for any PC used in the home or office. These also includ active PFC for better safety and reliability.
- Dual Railed (18 Amps per rail)
- Power Factor Control (PFC)
- Cooling: 12cm Red Fan
- New Version 1.3 / 2.03
- Silent with better ventilation
- ATX 12V compliant for most CPUs and mainboards
- Input Range : 230Vac, 10A, 50-60Hz
- SATA Connectors x 2
- Molex Connectors x 3
- Floppy Connector x 1
- 24pin Motherboard Connector x 1
- CPU 4 Pin Connector x 1
- 6 Pin PCI-e Connector x 1
Was £28.99 Inc. VAT
ORDER NOW
OCZ CoreXtreme 500w '80 Plus' Power Supply @ £26.99 inc VAT
The OCZ CoreXStream Series is the ideal value upgrade to satisfy essential computing needs with worry-free compatibility. The PSU is kept supremely cool with a load-controlled 120mm fan to remain quiet under load, and provides ample cable lengths for your home system application. Featuring up to 80% efficiency under typical load environments, this power supply remains rock solid and stable under pressure. Combined with a sleek look and elegant black powdercoat finish, you can be rest assured this PSU will look as good as it performs in your home office system.
- Ideal value option for home users and upgraders on a budget
- Ample cable lengths to suit various applications and system configurations
- Continuous output rated at 30¢XC ambient temperature
- 80% efficient at typical loads
- Dual +12V rails for efficient power distribution in your system.
- Compliant with ATX12V v2.2 standard for worry-free compatibility
- A temperature and load controlled 120mm fan for whisper quiet operation
- ErP compliant for low power usage in standby
- Active Power Factor Correction (PFC) to effectively regulate input voltage
- Heavy-duty protection circuitry, (over-voltage, over-power, and short circuit) for protecting your valuable components
- Safety Approvals: CUL, CE, CB, FCC Class B, TUV, CCC, C-tick
- Elegant black powdercoat finish for a sleek and simple look
- 3-Year OCZ PowerSwap Warranty, no endless return-for-repair loops
- 1 x 20+4-pin ATX
- 1 x 4+4-pin ESP/12V CPU
- 1 x 6+2-pin PCI-E
- 1 x 6 pin PCI-E
- 2 x 4-pin Peripheral
- 4 x 5-pin SATA
- 1 x FDD
Was £32.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Logitech G300 Gaming Mouse (910-002489) @ £25.00 inc VAT
The Logitech® Gaming Mouse G300 gives you more power, more control and more loot. Nine programmable controls let you move keyboard commands to buttons that are in easy reach. Onboard memory allows you to store up to three game or player profiles on the mouse. You can move it between computers without having to reconfigure it every time you do.
- Ambidextrous Design
- Corded
- Custom-Color LEDs
- Ergonomic
- Forward/Back Buttons
- Full-Speed USB
- Gaming
- High-Definition Optical Sensor
- Optical Sensor
- Programmable Buttons
- USB connection
Was £29.99 Inc. VAT
ORDER NOW
SteelSeries World of Warcraft Legendary Mouse (62050) @ £25.00 inc VAT
The SteelSeries World of Warcraft® MMO Gaming: Legendary Edition was co-developed with Blizzard Entertainment to bring players a uniquely sized, comfortably shaped, and easy to configure mouse that enhances their experience and improves their gameplay. Its 11 programmable buttons have been placed in a convenient, easy to reach layout on a medium-sized ergonomic mouse. Users can configure their set-up from button assignment to macro creation from directly within the game and choose from the 11.8 million color illumination options. The unique lightning bolt design is inspired by the legendary sword Thunderfury, evoking the power of the Blessed Blade of the Windseeker. This sword is the final reward at the end of a long and difficult quest – players who achieve this have truly earned the right to wield a weapon of great power and prestige.
- Cord Length (m): 2
- Cord Length (ft): 6.5
- Connection Type: USB
- Documentation Type: Quick Start Guide
- Number of Programmable Buttons: 9
- Number of Buttons: 11
- Frames per Second: 3600
- Counts per Inch (CPI): 3200
- Lift Distance (mm): 2
- Lift Distance (in): 0.079
Was £29.99 Inc. VAT
ORDER NOW
Xebec-tech HTPC/Console Bluetooth Keyboard @ £27.98 inc VAT
Introducing our second Bluetooth enabled keyboard. The famous and loved htpc is back but with an increased range of up to 15 metres using Bluetooth technology. It is now possible to enjoy the wonders that this versatile, light and compact keyboard with greater distances from your system.
The htpc is the ideal home theatre entertainment system solution. It is a mini keyboard with a whole host of built in function keys and specially adapted features.
To access the wonders of this keyboard. Your system will require a built in Bluetooth system. However if it doesn't have this, fear not-because via a Bluetooth dongle you can also enjoy the use of the htpc bluetooth.
The htpc is the ideal controller for your home theatre entertainment systems. It is fundamentally a mini keyboard for home theatre use, ideal and specially developed for use with widows media centre enabled PC’s.
The htpc Bluetooth increases the range of operation by 50% compared to the previous 2.4GHz htpc. You can now control your home theatre system from an even greater distance.
73 keys - 13 hotkeys (including 11 media hotkeys) and 11 further enhanced function keys
11 media hotkeys are:
www, e-mail, back, forward, previous track, next track, play/pause, stop, volume up, volume down and mute
- 11 further enhanced function keys (activated via the "fn" key)
- 6 MCE hot keys: My music, my video, my picture, my TV, my radio and DVD
- Gestures on the touchpad include 2 finger scrolling
- Built in and ergonomically placed rear positioned left and right click buttons
- 10-15m wireless range due to a Bluetooth connection
- Simple installation procedure using an on screen pin entry system
- Power saving On/off switch
- 73 keys- 13 hotkeys (including 11 media hotkeys) and 11 further enhanced function keys
- 11 media hotkeys are: www, e-mail, back, forward, previous track, next track, play/pause, stop, volume up, volume down and mute
- 11 further enhanced function keys activated via the "fn" key
- Weight: 170g
- Dimensions: 163 x 121 x 28 mm
Was £30.98 Inc. VAT
Only £27.98 inc VAT.
ORDER NOW
TT eSports Challenger Gamers Keyboard @ £26.99 inc VAT
This keyboard offers a unique cooling solution for your hands when the heat of the battle takes its toll on you. Allowing you to game under many different conditons you will be razor sharp at all times.
- Interface: USB
- Operational systems: WindowsR 7/Vista/XP
- Number of Macro keys: 6
- Number of Multimedia keys: 7
- 2.0 USB port: 1
- Switch lifecycle: 10 Millions
- Cable length: 2m
- Body dimension (LxWxH): 480x 205.5x 25mm
- Fan Speed: 6,000 RPM(±15%)
- Max. airflow:2.7CFM
- Noise level:21.7dB
- Rate voltage: DC 5.0V
- Life expectancy: 50,000 HRS
- Body dimension (LxWxH): 30x30x10mm
Was £29.99 Inc. VAT
ORDER NOW
Razer Goliathus Extended Mouse Mat - Speed @ £25.00 inc VAT
Engineered to exceed the exacting demands of the world's top professional gamers, the highly-adaptable Razer Goliathus Speed Edition successfully melds the full-scale speed, acceleration and razor-sharp responsiveness of hard mats with the precise control and comfort offered by uncoated soft pads. Boasting an improved iteration of Razer’s award-winning woven fiber technology, an extra-large size and an exclusive limited edition design, every inch of the Razer Goliathus Speed Edition’s durable surface is a glide-versus-resistance sweet spot, making it suitable for all mouse sensitivity setups and playstyles.
- Advanced Cloth Weave For Unbridled Speed And Effortless Control
- Pixel-Precise Targeting And Tracking;Optimized For All Mouse Sensitivity Settings And Sensor - Types;Extended size (920 x 294 x 4.3 mm)
- Limited Edition Design
- Rubber base for a secure grip on smooth surfaces
- 2 Years Warranty
Was £29.99 Inc. VAT
ORDER NOW
Microsoft Xbox 360 Wireless Controller - PC / Xbox 360 (JR9-00010) @ £25.00 inc VAT
The Xbox 360 Controller for Windows works with most Windows based PCs and Xbox 360, delivering a consistent and universal gaming experience. Get a better feel for the game with vibration feedback ensuring riveting game play every time. Part of the new Game Precision Series, the Xbox 360 Controller offers precision, comfort and control that will set the standard for next-generation game controllers. The pad has precise thumb sticks, two pressure-point triggers, and 8-way directional pad for enhanced PC gaming. Integrated 2.4 GHz high-performance wireless technology lets you control the action from up to 30 feet away
- Integrated 2.4 GHz Wireless
- For PC and Xbox 360
- Vibration Feedback
- Ergonomic Design
- Xbox Live Play - Integrated headset jack for PC headsets and Xbox Live play
- Includes Receiver
Was £27.98 Inc. VAT
ORDER NOW
saying ocz is amazing is a bit strong me and my mate had exact same ocz psu his melted mine had smoke pouring out :p
decent yes amazing no
I looked at that bluetooth keyboard earlier but it seemed to be missing some key details. I could probably go google the manufacturer's site or *cough* a competitors *cough* - what can I say, google can be fickle as to who it lists - but might be worth you having them since I can't imagine anyone would buy before knowing the answers.
Does it charge via USB or do you replace the batteries? What type? How long is it expected to last between replacement/recharging?
A quick scavenge pulled up the following consensus (the manufacturer's site seems pretty bare on these details themselves too):
- Takes 2xAAA batteries
- Some are provided in the box, but not rechargable
- No indications on lifespan
