Guild Wars 2
I've not really had any performance issues - Not badly anyway. Tend to have a bit of a buffer time for the cities, but that's it.
Did anyone have frame rate problems during the beta?
I didn't play for long. Didn't want to ruin my experience but it seemed to struggle for me.
Running 1920 x 1080, Medium pre-set. Specifications in my sig.
Crossfire was broken for me. Couldn't get over 30% GPU usage, and the frame rate dropped pretty bad sometimes. It runs fine on a single 6950.
Aye thats the thing that had me puzzled usually get confirmation email pretty quick but had nothing sent to me at all, am sure i put in the correct email addi.
zia
I resent it, if u need I can pm u the email address u signed up with.
Nope still nothing,hmm may well be my own stupid fault would be grateful if you could pm me the email addi i used or would it be better to delete application and start again?
Thanks zia
Trying to work out if my system will be able to handle this but struggling to work it out as I'm a little out of date on how things compare. My system;
AMD 7850 2.8GHz
4GB Ram
ATI Radeon HD 4800 Series
Anyone?
Thanks
Thanks zia
Mmm I think I may have somehow messed up ur application while doing someone's else, add iPad fat fingered problem, pm me the email address you want to use and I will do the rest for you.
AMD 7850 2.8GHz
4GB Ram
Hey, you should be ok at running it around low to medium, but pushing to highest quality you'll get frame drops and FPS lag in dense areas.
If your looking for better performance, i'd conside upgrading if you can afford it.
Something higher spec that wll match your motheboards socket and maybe a newer grphics card.
http://www.overclockers.co.uk/showproduct.php?prodid=GX-163-MS&groupid=701&catid=56&subcat=1866
Its only £100 and its a lot better then your current.
managed to beat factions and 90% of eye of the north this weekend.
Should be at 12/50 by the end of tomorrow :)
Then the hard work and the grinding begins to get the hero armour, weapons and my armour I need for 30/50
I'm doing Eye Of The North now, not done a great deal, find it hard to play more than a hour at a go for some reason :(
Any ocuk guild wars about still or is it all pretty much solo now?
There is the Immortals guild which leechs most of the OCUK MMO community, only downside with them is wab the guild leader. He's a bit like Marmite, most people don't like him, but there are some that don't mind the taste.
There are some other guilds who are accepting members from OCUK and i would suggest you look around the last couple of pagess to find them.
This is for guild wars 1 btw not gw2, already have a guild for that :)
Nice work.
I did a few random Asura VQ's over the weekend and maxed out my Asura rank at last, so just Ebon to do now (sat on 110k points atm).
Didn't have much time to play over the weekend or I'd have gotten the both out of the way. Gotta love double points weekends.
@wab
I tried to register on the homepage but got no activation email, tried twice :( Was under the same name I use here, LoopyOrc.
Send me you email you used m8 and I will do the rest.
@wab
I'm the exact opposite, I found it very hard to stop playing. I've been really enjoying playing it again.
Not sure why but I seem to be struggling to play this game, find the quests tough to do, not all but quite a few, which surprise me as I normally ok in most MMO and was fine in this before.
ask around here I'm sure you will find players to group up with you
Is there a way I can pm you it on here?
yes via the trust system, or just email me at [email protected]
Thanks zia
You sorted now m8, I emailed you with username and PW for your account.
Added Loopy you sorted as well sent you a email with everything you need to log in.
Looks like The Immortals have a pretty big roster and is still growing, hopefully we will see some ownage in WvW! ;)
