**** EPIC MONTH END CASE DEALS ****
8 Sep 2003
Was 150 yds from OCUK - now 0.5 mile; they moved
Here are some deals that are live just for today and tomorrow. Grab a deal now!
Aerocool Vs-4w Midi-Tower Windowed Case - Black @ £26.99 inc VAT
This case is one fo the best value cases in the market today, if not THE BEST! The chassis is solidly constructed with 0.5mm SGCC. It is also beautifully finished with "all black" interior and it includes many advanced features even for the most demanding gamers and enthusiast. It has great expandability and versatility. The chassis supports 4 x 5.25" devices and 5 x 3.5" HDD's. The VS-4 also supports long high end VGA cards up to 290mm. If you remove the FDD rack this is increased to 430mm in length. Airflow is unrivalled in this chassis with the ability to install 4 x 120mm fans.
- High performance "Mid-Tower" for gamers and enthusiast.
- Solidly constructed chassis – 0.5mm SGCC.
- ALL BLACK interior for a unique touch!
- Supports longer high-end VGA cards up to 290 mm/430mm (FDD rack removed).
- Supports 4 x 5 1/4" bays and maximum 5 x 3.5" HDDs (internal)
- 90 degree retractable HDD bracket.
- "Easy-install" screw-less kits for the 5 1/4" devices
- Pre-drilled cable management holes.
- CPU hole is pre-drilled on the MB plate for ease of CPU cooler assembly
- Install up to 2 x12cm fans at side panel (optional) / 1x12cm at rear (included) / 1x12cm fan in front (optional)
- Bottom PSU position enables PSUs to suck in cold air for better cooling.
- Water-cooling holes are pre-drilled to support water-cooling systems
- 2 x USB/ Audio+Mic (AC’97 + HD audio)
Was £29.99 Inc. VAT
Only £26.99 inc VAT.
ORDER NOW
Akasa Venom Strike Full Tower Gaming Case - Black @ £89.99 inc VAT
The strike of the Akasa Venom is deadly, with superior looks, styling and killing instincts.
- Material: SECC 0.8 / 1.0mm
- Compatible motherboard types: Micro ATX / ATX / E-ATX / XL-ATX
- 5.25" external bays: 6
- 3.5" external bays: 1
- 3.5" internal bays (2.5" HDD/SSD supported): 6
- Front Cooling: 1 x 23cm fan with white LED (included)
- Top Cooling: 1 x 23cm fan (included) or 2 x 12cm fan (optional) or 2 x 14cm fan (optional)
- Back Cooling: 1 x 14cm fan (included) or 1 x 12cm fan (optional)
- Side Cooling: 4 x 12cm fan (optional) or 1 x 18-23cm fan (optional)
- Bottom Cooling: 1 x 12cm (optional) or 1 x 14cm fan (optional)
- Fan controller: Controls 6 fans simultaneously with 40W combined maximum wattage
- Dust filter supplied
- I/O Ports: 1 x USB 3.0 , 3 x USB 2.0 , 1 x eSATA , HD audio in / out (AC’97 compatible)
- Expansion slots: 10
- Dimensions: 591 x 555 x 232mm(H x D x W)
- Weight: 12.6kg
Was £104.99 Inc. VAT
Only £89.99 inc VAT.
ORDER NOW
Anidees AI-6B Midi Tower Case - Black @ £84.98 inc VAT
The AI-6 gives an immediately clear first impression of quality and elegance. The Front cover shows a fairly large unit which houses a plastic exterior, with a brushed aluminum centre. In between lie a set of stealthy and concealed air vents, which should ensure good cooling.
This look is made possible through a closed front door, which is open when delivered to the left, this can be switched by the user to the right if required. If you open it, one sees a rectangular mesh field in the lower and upper area. The drive bays are provided by three 5.25-inch apertures. For each of them they can be cut away in order to push through an external 3.5-inch device.
Although only an adapter factory setting of one of three 5.25-inch slots at Al-6 is, but those frames can be conveniently buy more if needed. The lid of the clear line is continued by the I/O panel which is inserted inconspicuously. Two USB 3.0 ports that are present in addition to audio connectors and four USB 2.0 and are connected internally.
Under the removable cover part you will find a very good mesh surface, which ensures that a radiator with a size of up to 280 mm which can optimally cool with a good deliver fresh air. Alternatively, it is also just two 140s or 120s fan positioned there. The same applies to the front, where two fans of both formats can be accommodated, while the rear has only one 120-mm fan space.
Dimensions: 207 x 509 x 527 mm (W x H x D)
Material: steel, aluminum
Weight: 11 kg
Color: Black
Form Factor: ATX, Micro ATX, Mini-ITX
Front Cooling: 1x 140 / 120 mm (front, 120 mm optional)
Rear Cooling: 1x 120 mm (rear) / 1x 140 / 120 mm (front optional)
Top Cooling: 2x 140 / 120 mm (lid, optional)
Filters: Front & Back
Drive bays: 3 x 5.25 inches (external) / 1 x 3.5 inches (external, instead of 1x 5.25 inch) / 7 x 3.5 inch / 2.5 inch (internal)
Power Supply: Standard ATX 1x (optional)
Expansion Slots: 8 (without tools)
I / O Panel: 2x USB 3.0 / 4x USB 2.0 / 1x each Audio In / Out
Maximum graphics card length: 428 mm
Features: Elements made of brushed aluminum
- Cable Management
HDD and power supply decoupling
- Removable hard disk cages
Was £99.98 Inc. VAT
Only £84.98 inc VAT.
ORDER NOW
BitFenix Shinobi USB3.0 Gaming Case - Black @ £44.99 inc VAT
Named after some of the most feared assassins of the modern age, Shinobi empowers the digital warrior to silently and efficiently dispatch his opponents. Maximum expansion and compatibility with long graphics cards enables you to equip Shinobi with the tools you need to get the job done. Superior cooling options allow the system to stay cool and collected during the heat of battle, while a sophisticated yet understated styling shows the opposition you mean business.
Killer Looks
Shinobi carries through the signature BitFenix design philosophy of clean lines, understated elegance, and modern styling. If looks could kill, a glance at Shinobi could be your last.
Choose your destiny
The stealthy digital warrior must adapt to their environment. Available in with or without a windowed side panel, you can choose the Shinobi that blends perfectly with your surroundings. Whether you choose to walk the path of light or darkness, Shinobi has you covered.
Maximum Expansion
Serious rigs require serious hardware. That's why Shinobi is engineered to handle up to three 5.25" drives or eight 3.5" hard disks. You can also install a 2.5" SSD with the included adapter. Best of all, Shinobi can easily accommodate long graphics cards, which means that you can outfit it with the hardware necessary to eliminate the opposition.
Efficient Cooling
The effective gaming rig, like the warrior who wields it, must be cool under fire. Shinobi is adorned with unique mesh areas that can quickly dissipate excess heat. Shinobi can accommodate a bevy of fans - up to seven 120mm or two140mm fans can be installed to ensure that all hardware stays as cool as the blood running through an assassin's veins.
Plenty of connectivity
The efficient warrior must have easy access to all the tools they need to get the job done. Equipped with no less than four USB 2.0 ports, Shinobi offers plenty of connectivity for all your USB devices so that you can keep you gear connected and ready for battle.
DIY Friendly
Fighting should be done in game -- not with your hardware. Shinobi comes with a wealth of DIY-friendly features, ensuring that getting your system setup is quick and efficient. A CPU cooler cutout makes it easy to change out your CPU cooler should the need arise. Shinobi comes with filtered fan intakes, keeping the interior clean and your system looking great. Shinobi Window even comes with convenient tool-free drive locking mechanisms for ultimate convenience.
BitFenix Quality
Shinobi comes with all the amenities and design touches characteristic of BitFenix chassis. BitFenix SofTouch™ Surface Treatment for resistance to fingerprints and stains surrounds the brushed gunmetal BitFenix logo emblazoned on the front. A luxuriously black coated chassis exudes both quality and refinement. With Shinobi, users can experience BitFenix quality both inside and out.
- Dimensions: 205 x 460 x 490mm
- Motherboard Sizes: Mini-ITX, mATX, ATX
- 5.25" Drive Bays x 3
- 3.5" Drive Bays x 8
- 2.5" Drive Bays x 2
- Front Cooling: 2 x 120mm Fans (optional)
- Rear Cooling: 1 x 120mm Fan (included) or 1 x 92mm Fan (optional)
- Top Cooling: 2 x 140mm Fans (optional) or 2 x 120mm Fans (optional)
- Bottom Cooling: 1 x 120mm Fan (optional)
- Expansions Slots: 7
- I/O Ports: 2 x USB2.0 / 2 x USB3.0 & 1 x Audio
Was £49.99 Inc. VAT
Only £44.99 inc VAT.
ORDER NOW
Cooler Master CM-690 II Nvidia Edition Advanced USB3.0 Dominator Case - Black/Green @ £84.98 inc VAT
The wildly popular and top-selling CM 690 II Advanced now comes in a NVIDIA Certified Edition. It has been stylized with a NVIDIA themed side panel, badging, and clean looking external and internal accents. This spacious mid-tower has room for up to 3 graphics cards, high-end CPU coolers, top or bottom mount liquid cooling radiators and a 1.8”/2.5” drive adapter. It also features a much improved airflow with oversized mesh and plenty of space for up to 9 fans. Maintenance is a breeze with tool-free drive bays, elegantly simple cable management, and a large CPU cooler retention hole.
- Oversized front and top mesh design for superb ventilation
- Accommodates 120 x 240 mm radiator inside the top or bottom
- Dust-control filters for all meshed areas
- Air cooling support for up to 7 fans
- External SATA X-dock
- Front Green LED fan on/off switch
- Rear retaining holes for water cooling kit
- Includes 1.8" & 2.5" HDD and SSD adapter
- Cable managment and CPU retaining hole for easy maintainence
- Includes VGA card bracket (supports triple GPU card)
- Dimension (W / H / D): 214.5 x 511.8 x 528.8 mm
- Front Cooling: 140 x 25 mm Green LED fan x 1 / 1200 RPM / 19 dBA
- Rear Cooling: 120 mm fan x 1 / 1200 RPM / 17 dBA
- Top Cooling: 140 x 25 mm fan x 1 / 1200 RPM / 19 dBA (supports 120 / 140 mm fan x 2)
- Bottom Cooling: 120 mm fan x 2 (optional)
- HDD cage Cooling: 120 mm fan x 1 (optional)
- VGA holder Cooling: 80 x 15 mm fan x 1 (optional)
- 4 x 5.2" Drive Bays
- 6 x 3.5" Drive Bays
- 2 x 2.5" Drive Bays
- I/O Ports: USB2.0 x 2 / USB3.0 x 2 / eSATA x 1 / Audio
- Expansion Slots: 8
- 2 Year warranty
Was £99.98 Inc. VAT
ORDER NOW
Cooler Master Elite 371 Midi Tower Case - Black/Silver @ £32.99 inc VAT
The new Elite 371 builds upon Cooler Master expertise and delivers high-end features in the affordable market space. Cooler Master believes that just because something is affordable, it doesn’t have to lack features or be a “budget” product.
The Elite 371 features a classic black Cooler Master design with clean, yet attractive lines. It has been built to last and uses high quality materials. It’s also been designed to keep the components inside the case cool and not only does it have space for plenty of additional cooling fans, but it can also be fitted with large CPU coolers, such as the Cooler Master Hyper 212 Plus.
- Filtered intakes on bottom and top
- Tool-Free mechanical design for quick assembly and maintenance
- Side ventilation holes for better cooling performance
- Easy access front I/O panel
- Supports long graphics cards including HD Radeon 5970
- Dimension (W / H / D): 190 x 424 x 497 mm
- Weight: 4.6kg / 10.1 lb
- M/B Type: ATX /Micro-ATX
- 5.25" Drive Bays: 3 Exposed
- 3.5" Drive Bays: 5 Hidden / 1 Exposed
- I/O Panel: USB 2.0 x 2 , Mic x 1 , Audio x 1
- Expansion Slots: 7
- Top Cooling: 120 mm fan x 2 (optional)
- Front Cooling: 120/140 mm fan x 1 (optional)
- Side Cooling: 120 / 140 mm fan x 2 (optional)
- Bottom Cooling: 80 / 90 /120 mm fan x 1 (optional)
Was £36.98 Inc. VAT
Only £32.99 inc VAT.
ORDER NOW
Cooler Master Elite 430 Windowed Case - Black @ £34.99 inc VAT
The Elite 430 Black was designed all-black interior coating with its main purpose in mind as such there’s plenty space for large graphics cards, no matter your brand preference. The Elite 430 Black also features plenty of cooling options and a well ventilated front mesh design to keep even the hottest system nice and cool.
- Interior black coating makes stylish inside looks
- Front 120mm fan with brilliant Blue LED provides the best airflow to HDDs
- Rear 120mm fan for high-efficiency ventilation
- Large transparent side window included
- Supports long graphics cards including Radeon HD 5970
- Front Cooling: 120 mm blue LED fan or 140 mm fan x 1 (optional)
- Rear Cooling: 80/90/120 mm fan x 1(optional) (120mm fan included)
- Side Cooling: 120 mm fan x 1(optional)
- Bottom Cooling: 80/90/120 mm fan x1(optional)
- I/O Port: USB 2.0 x2, Mic x1, Audio x1, 1394a x 1,(optional)
- Dimension: 190 x 424 x 490 mm (W x H x D)
Was £39.99 Inc. VAT
Only £34.99 inc VAT.
ORDER NOW
Corsair Vengeance C70 Midi Tower Gaming Case - Military Green @ £102.98 inc VAT
When it’s time to take your competitive gaming on the road, the Vengeance C70 mid-tower PC case is a great choice. It’s crafted out of solid steel and made to survive trips with less wear and tear, and the ergonomic carry handles help you move your gear with confidence. High-performance gaming hardware requires high-performance cooling. Vengeance C70 is equipped with three 120mm fans out of the box, with mounting points for seven more to meet your exact air cooling demands.
Vengeance C70 is also outfitted for liquid cooling upgradeability. You get 240mm radiator compatibility on top of the case, and if that’s not enough, you can remove the lower hard drive cage to fit a second 240mm radiator for a dual-loop setup.
A case is as much a part of your armory as any other component. With internal USB 3.0 connectors for modern motherboards, native SSD compatibility, eight expansion slots and room for long graphics cards, the C70 stands ready to take on any challenger.
Easy access side panels come off with quick-release latches. The optical drive bays and 3.5” hard drive bays are tool-free. Thumbscrews secure your graphics cards, and the hard drive cages can be easily removed for better airflow or additional expansion room. Cable routing tie-downs and built-in clamps keep your system tidy.
- Room for 2 x 240mm Radiators
- Tinted Side Window with dual fan mounts
- Motherboard Support: ATX & mATX
- Material: Steel
- Drive Bays: 3 x 5.25" & 6 x 3.5"/2.5" bays
- Cooling: 2 x 120mm intake fans and 1 x 120mm exhaust fan
- Front I/O Ports: 2 x USB3.0 / 2 x Audio
Was £112.99 Inc. VAT
Only £102.98 inc VAT.
ORDER NOW
Corsair Vengeance C70 Midi Tower Gaming Case - GunMetal Black @ £102.98 inc VAT
- Material: Steel
ORDER NOW
Corsair Vengeance C70 Midi Tower Gaming Case - Arctic White @ £102.98 inc VAT
- Material: Steel
ORDER NOW
NZXT Phantom 410 Enthusiast Midi Tower Case - Gun Metal @ £94.99 inc VAT
NZXT introduces the next descendant of the revolutionary Phantom, the Phantom 410. The beautiful and sleek Phantom design set the trend of all white chassis and idealized optimal expansion and cooling. In comparison to its predecessor, the Phantom 410 delivers more value for every dollar spent and possesses an acrylic window that allows gamers to admire the power of their rig.
The Phantom 410 features an innovative right mounted HDD rails, a solution for easy hard drive replacement. This mid tower comes equipped with a dual radiator water cooling solution with a clearance of 30mm, an interior pivot 120mm/140mm fan slot, the capability of installing up to 8 fans, and a single 30W fan control. The Phantom comes with up-to-date internal 2x USB 3.0 headers that directly connect to the motherboard. Be the envy of all PC gamers - the Phantom 410 is bringing sexy back.
- Clearance for top 240mm dual radiator for water cooling solutions
- Adjustable interior pivot 120mm/140mm fan slot for directional air flow
- Removable HDD cage to allow more room for extended video cards
- Innovative right mounted HDD rails for easy hard drive replacement
- Single 120mm/140mm side fan with acrylic window for interior viewing and cooling
- Front Internal 2x USB 3.0 headers, 2x USB 2.0, audio and microphone input
- 30W 3-step fan control for setting up your system for silence or performance
- Wire management support up to 25mm space for easy cable management
- Screw-less 5.25” and HDD trays that secures 2.5” SSD
- Cooling capability of up to eight fans (2x 120mm and 1x 140mm LED fan included)
- Dimensions(W x H x D): 215 x 516 X 532 mm
- Front Cooling: 2x120mm or 1 X 140mm (1x120mm included)
- Rear Cooling: 1 X 120mm (included)
- Side Cooling: 1 x 120mm or 1 x 140mm
- Top Cooling: 2 X 120/140mm (1 x 140mm included)
Was £109.99 Inc. VAT
Only £94.99 inc VAT.
ORDER NOW
NZXT Phantom 410 Enthusiast Midi Tower Case - White/Purple @ £84.98 inc VAT
Was £94.99 Inc. VAT
ORDER NOW
NZXT Phantom 410 Enthusiast Midi Tower Case - Black/Orange @ £84.98 inc VAT
Was £94.99 Inc. VAT
ORDER NOW
