- 8 Sep 2003
- Was 150 yds from OCUK - now 0.5 mile; they moved
Pricing says all that is neccessary!
Only till 5pm tomorrow!
Boogie Bug AimB.Pad XL Gaming Mouse Surface @ £7.99 inc VAT
The AimB.Pad has been especially designed for gamers looking for precision, fluidity and the perfect harmony between slide and friction. This XL version also represents an essential tool for graphics designers, architects and other users looking for precision and wide movements. Its surface has been made with flexible textile material that not only assures fluidity and precision in the movements, but also allows the AimB.Pad to be folded, rolled up and transported.
- Dimensions: 450mm x 900mm
Only £7.99 inc VAT.
ORDER NOW
Boogie Bug AimB.Pad "Extreme" XXL Gaming Mouse Surface @ £12.98 inc VAT
We thought that the Aim.B Pad was the best and biggest mouse mat of all time. But what is this? Boogie bug have designed a BIGGER and BETTER pad! With a massive foot print of 120cm wide and 60cm deep your mouse, keyboard and desk will look smaller than ever.
The AimB.Pad has been especially designed for gamers looking for precision, fluidity and the perfect harmony between slide and friction. This XXL version also represents the same properties as the XL so it remains an essential tool for graphics designers, architects and other users looking for precision and wide movements. Its surface has been made with flexible textile material that not only assures fluidity and precision in the movements, but also allows the AimB. Extreme Pad to be folded, rolled up and transported.
If you don't want a new mouse pad then you should buy this anyway - you can use it as a quilt, a blanket or even as a dinner table cover!
- Dimensions: 120cm x 60cm
Only £12.98 inc VAT.
ORDER NOW
Only £7.99 inc VAT.
ORDER NOW
ORDER NOW
