i had a bit of spare time yesterday so decided to get the rear trailing arm out of the garage and start replacing the upper and lower (spring and camber) arm bushes
i rigged up a tool and got them removed after a moderate amount of swearing.
the replacement bushes are lemforder and im using new upper ball joint bushes to go into both holes.
http://www.ecstuning.com/BMW-E46-M3-S54_3.2L/By_Brand/J-L/Lemforder/ES253001/
i offer it up to the lower hole and its snug, ie will have to be pressed in.
with the upper hole it just drops in the hole and with a few light taps goes all the way through and it does it with all four of the bushes i have
im buying a new vernier tonight to measure up as my old one has seen better days
both holes should be 45mm ish
i could understand if the top hole was damaged, egg shaped etc, but it seems to be perfectly round but easily 1mm larger
anyone come across something like this before?
