EK Supremacy opinions?
Performance wise it's probably as good if not a little better than the raystorm.
For looks I'm not much of a fan of the plexi and acetal versions, but the full copper/full nickel are stunning :D
I'm getting my plexi one soon :D
It's the best performing block for that price bracket I believe.
With high end blocks, they all perform within a few degrees of eachother, just go for the one that you think looks the best/matches the rest of your blocks.
You've linked to a copper plexi block. nickel plexi FTW xD
its the best performing block on the market.
but in honesty, you will see no real world difference between any of the blocks listed on ocuk :)
Black acetal looks like this.
