- 10 Jan 2012
Thanks mate, just about to order one - just read a great review on it.
If your planning on playing battlefield 3, a nvidia card would be a better choice.
@spixelspixel - it only helps if you get close to running out of VRAM. Otherwise it's pointless overhead. Even with 3 screens I run out of GPU power before VRAM.
However, those titles probably aren't the best examples of VRAM hoggers to test a 3GB cards utility.
Yep, someone really needs to do a proper review showing vram importance.
Somebody said here a few weeks ago that max payne 3 used 2.5gb with his 7970 (if I remember correctly) yet this http://www.techspot.com/review/537-max-payne-3-performance/page5.html shows that all the cards perform as they should, even the 1gb cards.
review sites tend to only test 1 or at most 2 cards, or the odd time they do a 3/4 card test they don't even do 3 screen tests, or they do 3 screen with no AA or something equally gay... it's almost as if they deliberately choose settings that the lower cards can also run just to show some bar graphs instead of having quad 4GB/3GB cards with figures and everything else as <10FPS
double VRAM cards are released with the idea of being used in 3- and 4-way combinations with 3+ monitors, which most review sites just don't have the kit sitting around to test properly
there's 2 sides to VRAM use... on the one hand, cards will make use of whatever they have, so maximum VRAM useage on a big VRAM card doesn't neccessarily mean that that is what you need, I've seen 2.4GB usage on BF3 on a 3GB card @ 1080, but it also runs fine at 1440p on 2GB cards, so 2GB is not a limit for BF3 on single screen setups - have seen 2GB become a limit for quad SLI 680's on 3 screens with 4xMSAA though
MaxPayne tells me in the menus that it needs 2.5GB to run at 1440p with 4xMSAA... but if I set it to OFF in the maxpayne menu, but turn it on in nvidia control panel, it works fine... so the maxpayne menu that guesses the VRAM is broken
MaxPayne is generally broken in my experience
that review of maxpayne, they are using no AA all the way through, so that will be keeping the VRAM requirement down... the max payne menu won't even let you turn on AA on 1GB cards so that's why they chose those settings, they have deliberately chosen settings that CAN play on 1GB
the only way you can tell what is a vram limit or not is by testing it
what does get a little annoying is when people who haven't tested a particular setup/settings but have used something else and then arbitarily apply that experience to all other games on the same amount of VRAM
I know I tend to bang on about BF3 on every thread regarding VRAM, but that is because it is the one game I've tested extensively on lots of different card setups with different VRAM amounts, so I can quite confidently say whether or not VRAM is a limit in that game
but it is why when someone comes up with a "shall I SLI 560ti/570" I always ask what games they play, because if they don't play things like BF3 then it may well not affect them
Another thing is that turning up AA/resolution not only increases vram usage but also decreases fps across the board at the same time. So sometimes when people say 'I'm vram limited because the game runs like crap when I turn on AA' it could just be limited processing power.
My opinion is still that vram is not as important as a lot of people make it out to be. I've read so many cringe worthy threads about vramWorst case scenario is that you have to put 1 or 2 graphics settings down a notch. Processing power > vram 99.9999 percent of the time.
Especially with recent generations where card manufacturers have been releasing double ram cards. I wonder how many people buy them simple because it says 4gb instead of 2gb, then proceed to game on 1920x1080.
This review is interesting - http://hexus.net/tech/reviews/graph...nster-hd-7970-toxic-6gb-three-screens/?page=4
But of course it had to be done with a monstrous overkill 6gb card and not a 1.25 vs 2.5gb or something.
snip
but a single 570 can run high settings on it's own anyway so what would be the point
