Best way to install new GPU into PC that's running on an iGPU?
Man of Honour
8 Nov 2007
Outer Space
Hey,
As title really, what's the best route to uninstall the iGPU then install the discreet card? Never had onboard like this before?
Just plug and play! If your MoBo supports Lucid virtu your iGPU will add to your GPU performance in applications. If it doesn't your bios will just disable it. Leave it enabled IMO if it does support it, adds about 5-7% in benchs etc.
