I guess I would consider one of these but the loss of desktop space would be a concern. I'd like to hope we'll oneday see 2560x1440 or 2560x1600 screens with 120hz. I think they would need to use displayport to achieve this for 3d but my card has displayport, even my current monitor has displayport so it must be possible.
Its already happened, you just have to overclock korean monitors. So yes, 2560 x 1440 at 120hz is possible over DL-DVI, although it is not supported![]()
chipachip - they are true 120hz monitors, achieved via overclocking. Only a specific model can be overclocked, on sale at a site I obviously can't name.
The DVI bandwidth is limited only by the cable itself, which seems to be around 130hz @ 2560x1440 on the better cables.
The DVI "standard" limits you to 85hz @ 2560x1440, but it is only a recommendation to prevent monitors killing graphics cards and vice versa.
My blood was boiling until I read the /sarcasm bit.
But.. but humans can't see above 30fps! There's no difference between 30fps and 120fps! So why do we need 144? :/
/sarcasm
When we get this monitor in our office I will let you know if we can overclock it!
tn panel says it all it could be 200hertz still wouldnt compare to an ips panel for quality![]()
