- 22 Mar 2009
- Cornwall
NVM
			True, and what do all these records show and indicate?
They show that our climate works in cycles and we are due a major shift in climate.
they are meaningless and they're very much cherry picked. especially the if it can double co2 in a century. Those numbers do not tell us anything with out natural co2 emissions and natural co2 absorption.
the fact they're rough estimates doens't matter, its the fact those numbers on their own are meaningless.
he has not done any claculations based on teh cycle. he has compared atmospheric co2 with man made co2 emissions. these are largely irrelevant without the other numbers i suggest.
you do realise that the mass of ice is forcing the sea levels up, so when it melts it stays pretty much the same level right?
I mean, I have never left ice to melt in a glass and come back to find the glass has overflowed
how do we know though. no records were recorded 500 years ago. how do you know these things aren't just long cycles that repeat themselves and nothing we do will stop that?
They're really not, all carbon in the oil and coal was sequestered away and out of the cycle, what with it being a few million years old.
Indeed.They show that the temperature cycle has never (never in relative terms) been not as rapid as in the last century, and the best fitting data for to explain the change in rate of change is human CO2 output.
especially the it doubles it in a centrally comment.
except that doesn't show us anything.
now calculate natural co2 release and natural co2 absorption.
cherry picking numbers doesn't help your point at all, as they are pretty meaningless.
Indeed.
A few things people need to understand.
Climate change scientists are not claiming that the temperature doesn't change on it's own in warming/cooling cycles - they are concerned about the SPEED in which it's occurring.
completely fantastical). What I meant to show was that human activity is on a scale where it can be reasonably compared global quantities (which is something a lot of people seem to ignore or reject).
again , you can not say that from your figures. you are using the wrong figures to try and prove a point.
So you would say the statement 'current human emissions would approximately equate to 1.5 times the current mass of CO2 in the atmosphere over the course of a century' is false? Note that it does not make any claims about how the atmospheric concentration would change.
Currently about 57% of human-emitted CO2 is removed by the biosphere and oceans
Actually, you're wrong to say that Jak needs to know these figures in order to work it out back-of-the-envelope style. You can simply compare net results - is the amount of CO2 in the atmosphere rising quicker than it used to? The answer is yes; therefore, more CO2 is being produced than the Earth's cycle-in-equilibrium.you need to know natural co2 emissions (which is far far higher than man made) and you need to know global absorption rate, then you can show what you are trying to say and you will have a very different number.
that's not what he claimed
jak731 said:Any one particular climate regime is in a delicate equilibrium. Plenty of natural events can cause it to change, this is not disputed. The argument is that humans are having a significant effect over the natural cycles. The fact that dinosaurs didn't drive suvs is mindless drivel.
Having a degree in physics I like doing simple 'back of the envelope' calculations to see if what people are saying appears to be in the right ball park. Consider this:
I'm afraid it was:
Humans will adapt, as they have for many years.
