difficult in such a small sig....
No i don't since i've never done it before i can't say it was something i struggled with... also i put the spaces in on purpose...
it's working now and it was just a problem with the Url as i could not find the image alone...
Could i ask how you found the direct link to just the image?
You seem to be great at sigs chris, any chance you could try this if you've got time?
	Can you alter slightly?
Cut his legs off to get closer shot of upper body and could you blur/blend the first picture into the 1 sign?
Also the right hand Side where the 1 is cut out doesn't work on black forum
Thx
	here's the 3 images you'll have to add links etc...
Would like a sig like Silver toungue, but with youtube instead of the circle and instead of EVe the specs in my sig
Helloo,
Could someone please make me a sig using the picture of my build below, my username (Kyzou), and my specs (In sig, ignore monitors, BR drive and "Custom Water Loop") with a kinda techy feel to it?
http://i47.tinypic.com/4qkcr4.jpg
Cheeeers.
  Could you please add that?
 Could you please add that?Would anyone be kind enough to change the entire background in this to white and change the dragons fire to red please?
Also, keeping it within forum forum siggy rules - many thanks
