Not impressed.
I've upgraded from a 280. I play @ 1680/120Hz.
L4D2 = I seem to have less FPS if anything. At best, it's around the same. I'm occasionally dipping into the 50s. WTF. It used to be around 120 more or less solid.
World of tanks. 45fps with everything turned on. 50-150 with most things turned off. There is probably an increase of 10fps here 'across the board'.
Quakelive is unaffected, as you'd expect for a 20~ year old game.
CPU is an i3-530 @ 3.3GHz.
Was I expecting too much? Driver issue (301.42)? £350 down and I feel like this was a pointless upgrade.
