- 26 Oct 2002
- Norwich
Do you wear a helmet when you're driving, or maybe when you go to the pub? Both of these are more likely to result in a head injury than riding a bike.
Helmet compulsion is a very bad idea, as for the small amount of injuries it might save, more heath problems would be caused by the reduced numbers cycling. Cycling isn't dangerous and adding PPE requirements only makes it seem like it is to the general public.
For what it's worth I always use a helmet when mountain biking but if I'm out on the road or just having a pootle along the canal I don't bother.
Thats a stupid argument, you are far more likely to suffer a injury/death in a cycling accident than you are in a car, wearing a helmet reduces the risk of a serious injury or death caused by a head impact. Modern cars are designed to be pretty friendly when in contact with pedestrians/cyclists but the major danger is the head impact on the windscreen, there is no doubt wearing a helmet is safer than not if involved in a collision on your own or with a vehicle.
Whether you wear one or not is of course up to you, you only get one life so seems odd to take a gamble as i imagine a massive percentage of accidents involving cycles are not the fault of the cyclist and the cyclist probably knows very little about it.
That doesn't mean i think an arbitrary rule should be brought in, Darwin works pretty well as it is now.
