Been thinking over what hardware I want in my build, already got a watercooled CPU and GPU and was going to transfer that into my TJ07.
Ive since decided I want to build something a little bit better, airflow through the top of the TJ07 wont be great once I've got a back panel without the fans and an acrylic top window so I'm looking at seling my current mobo and CPU and going for a fully watercooled system.
I know I probably don't need to go so extreme, I just want to though!
Now it seems mobo water blocks are few and far between so what are my options?
Looking at an i5 CPU, would like space for 2 GPU's, ideally both x16 slots.
Water block wise I'm thinking copper & acetal to go with my CPU block, also need to find a copper & acetal block for my 580.
Now on to the budget!
This build will probably take a while so I'll be buying the mobo first and leave the CPU until I need it, so for starters just the water block and mobo and I'm guessing I'll need ~£200?
I'll be selling my current hardware first si that help towards the cost hopefuly!!
Cheers
Cheers
