Galaxy S2 - how to get back to stock?
A word of warning - don't flash a 4.0.4 ROM at the moment, as if you wipe in CWM recovery (or even sometimes stock apparently), it can properly brick the device.
Using Odin, put the phone in download mode and flash the latest 4.0.3 XEU unbranded ROM. Then you should be able to use Kies as normal, which will update you to a 4.0.4 if you want. Just be careful...
so you cannot use clockwork with 4.0.4 at all? even if you update via kies?
if so it looks like 4.0.3 will do but what are the differences between the two?
