3 Aug 2012 at 20:18 #1 McGraw McGraw Soldato Joined 16 Jan 2006 Posts 3,046 ...tried to switch to AHCI and it won't boot. I've installed all the mobo drivers. Is it possible to do this or should I just reinstall? Is it even worth it? Cheers.
3 Aug 2012 at 20:24 #2 RJC RJC Don Joined 29 May 2005 Posts 29,080 Location Kent This may work on Windows 8, have a look at the link below: http://support.microsoft.com/kb/922976
3 Aug 2012 at 20:34 #3 McGraw McGraw Soldato OP Joined 16 Jan 2006 Posts 3,046 Thanks I'll have a look
3 Aug 2012 at 21:24 #4 madindehead madindehead Soldato Joined 30 May 2009 Posts 4,629 Location Maidenhead McGraw said: ...tried to switch to AHCI and it won't boot. I've installed all the mobo drivers. Is it possible to do this or should I just reinstall? Is it even worth it? Cheers. Click to expand... Normally, if you do this with Windows 7, it does this too. Safer to just install it properly with AHCI mode to begin with
3 Aug 2012 at 21:30 #5 Mei Mei Soldato Joined 3 Jan 2012 Posts 3,980 windows 8 manager has the option to fix this i guess it just makes the registry changes for u anyway thought it might help, free app
3 Aug 2012 at 22:24 #6 McGraw McGraw Soldato OP Joined 16 Jan 2006 Posts 3,046 Thanks everyone but that registry key doesn't seem to exist in Windows 8 and I can't find the part of Windows 8 manager that is supposed to do it. Any further pointers? Cheers.
4 Aug 2012 at 00:45 #7 Orcvader Orcvader Soldato Joined 11 Oct 2009 Posts 16,954 Location Greater London Reinstall Windows while the SATA mode is in AHCI?
6 Aug 2012 at 09:33 #8 McGraw McGraw Soldato OP Joined 16 Jan 2006 Posts 3,046 Thanks. I've found a link on how to do it but think I will leave it until we reinstall the retail version
