** Today Only 04/08/2012 - 05/08/2012 - IIyama Prolite E2473HDS 24" Monitor - Black + Samsung Gree 8
20 Jul 2009
The bleak North East arm pit of Britain
Hello
Today only we have we have 20 units of the IIyama Prolite E2473HDS 24" Widescreen LED Monitor - Black
We also have 50 units of Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit
See below for the deals :)
Samsung Green (MV-3V4G3D/US) 8GB (2x4GB) DDR3 PC3-12800C11 1600MHz 30nm Dual Channel Kit @ £47.99 inc VAT
nonl2br
These Samsung Green kits are a world first using 30nm technology. This results in lower power usage, extended life and ultra low profile making them compatible with all DDR3 solutions including small form factor.<br/><br/>
Boost performance with Samsung genuine PC memory. As the number one memory supplier in the world, Samsung DRAM modules are made with 100% Samsung components. With the 30nm-Class DDR3 1600MHz Extreme Low Voltage UDIMM module from Samsung, you can get faster speed and greater reliability from your computer while consuming less energy. Use Samsung UDIMM DDR3 memory to replace or increase the memory in your desktop or server. This Samsung DDR3 memory module employs 30-nanometer technology and, as a result, uses up to 65 percent less power and is only two-thirds the size of conventional 60-nanometer memory modules. This version of Samsung DDR3 has a 8 GB capacity (2 DRAM modules, each with 4 GB). <br/><br/>
The other major advantage of these modules is their overclocking ability, in our own testing we achieved 2400MHz with CAS 11-11-11-28-1T timings with just 1.55v resulting in staggering levels of performance.
<br/><br/>
<strong>Features:-</strong><br/><br/>
- Model Name: MV-3V4G3D/US<br/>
- Main Board: INTEL/AMD<br/>
- System: DESKTOP/SFF<br/>
- System Type: DDR3<br/>
- M/B Chipset: INTEL P67, Z68, Z77, X79 & AMD Chipsets<br/>
- CAS Latency: 11-11-11-28 1N<br/>
- Capacity: 8GB (4GBx2)<br/>
- Speed: DDR3-1600 (PC3-12800)<br/>
- Test Voltage: 1.25-1.55V<br/>
- Registered/Unbuffered: Unbuffered<br/>
- Error Checking: Non-ECC<br/>
- Type: 240-pin DIMM Low Profile<br/>
- Warranty: Lifetime<br/>
<br/><br/>
<strong>
Overclocking Features (Not Guaranteed)</strong><br/><br/>
- 1600MHz (7-8-8-24 1N) @ 1.40v<br/>
- 1866MHz (9-9-9-27 1N) @ 1.40v<br/>
- 2000MHz (9-10-10-28 1N) @ 1.45v<br/>
- 2133MHz (10-10-10-28 1N) @ 1.45v<br/>
- 2400MHz (11-11-11-28 2N) @ 1.50v<br/>
- In our own in house testing we were able to achieve all the above clock speeds on an Asus X79 platform with 4x4GB modules (16GB total) SuperPI Stable too, 32M<br/>
Was £59.99 Inc. VAT
Only £47.99 inc VAT.
ORDER NOW
IIyama Prolite E2473HDS 24" Widescreen LED Monitor - Black @ £143.99 inc VAT
The ProLite E2473HDS LED-backlit monitor, finished in the latest glossy-black, is a full high definition 24" display that features all the benefits this technology affords. The high specifications of the monitor include the 5,000,000:1 ACR, triple input connectivity (D-Sub, DVI-D, 2 x HDMI) and fast 2ms response for excellent sharpness in high definition video. VESA mount compatibility along with one HDMI input and headphone connector on the side of the cabinet ensures great comfort of usage.
Features:-
- Diagonal: 23.6"
- Panel: LED-Backlit
- Display area: h x w 293.2 x 521.3 mm; 11.54" x 20.51"
- Response time: 2 ms
- Contrast: 1000 : 1 typical
- Contrast: 5 000 000 : 1 ACR
- Brightness: 300 cd/m² typical
- Connections: D-Sub, DVI-D & 2x HDMI
- Viewing zone: horizontal/vertical: 170°/ 160°; right/left: 85°/ 85°; up/down: 80°/ 80°
- Display colour: 16.7 million
- Pixel pitch: h x v 0.2715 x 0.2715 mm
- Native resolution: Full HD 1080p, 1920 x 1080 ( 2.1 megapixel)
- Horizontal sync: 24 - 80 KHz
- Vertical sync: 55 - 75 Hz
- Synchronization: Separate sync
- Aspect ratio: 16 : 9
- 3yr On-site Warranty
Was £159.95 Inc. VAT
Only £143.99 inc VAT.
ORDER NOW
Just when I was thinking of getting new memory you guys do this :D
It's also worth noting the 16GB dual/quad pack is £90 today only too, saving ~£6 over two 8GB kits :)
the monitor is a smashing deal. i'd get one, too bad i dont have free p&P yet though =x
That's unfortunately stopped me from jumping on the bandwagon for some of the great deals they have. The postage royally affects prices for the newcomers, We'll just have to wait until we get our free postage/ a ridiculous deal pops up that outweighs high postage xD
the p&p is fine if you're getting multiple parts at once, but if you're buying as and when great one day deals are on, then yea, it'll cost an arm and leg
Has the Samsung always been 30nm as i seem to remember 20nm green for some reason?
I think you may be spot on with that, perhaps the wrong description on it?
According to Samsung the 20nm stuff is the 'G3' while 30nm stuff is 'G2'.
As the item description says G3 (MV-3V4G3D/US) I can only presume this IS 20nm not 30nm?
Hopefully a member of staff will clear this up :)
Indeed it does, I was going to grab one of those boogiebugs XXL until I saw the £9 postage or so that came with it and then the i5 3570k popped up and now this cheap ram -.-
Van dammit. Really could do with that memory...she'd go spare, the cpu hasn't even arrived yet.
