ML Ethernet + WiFi Download speed
18 Oct 2002
This maybe a stupid question:
If I'm connected to the net via WiFi and then plug in an ethernet cable, System Preferences/Network says that both are connected.
Does this mean that I'm using both channels to download, does it automatically switch to the fastest connection, or does it just use the first channel connected (in this case WiFi).
I may be wrong... but I think it automatically favours a physical connection. So if you're on wifi and you put an Ethernet cable in, it'll run through the Ethernet cable.
But like I say, I could be wrong :p
