Hey Guys,
Would like some assistance on overclocking this card if possible please. The card is factory overclocked to 1006Mhz Core (Boosts to around 1188Mhz) and 1552Mhz Mem (1.175V load).So I'm using the EVGA PrecisionX tool, which has some new features present for these 6** range cards, which I believe to be 'Boost' and 'Power Target'. I've setup a good fan profile which keeps the card nice and cool, and noise levels acceptable (considering i wear headphones, absolutely fine)
I start with running heaven in a window and keeping the card at stock. Heaven puts the GPU load at a constant 99% and win loop forever.
I'll then open Precision X and bump the Power Target from 100%, to 111% allowing the card to use 111% TDP.
Next I'll do what I consider a moderate? overclock and bump the GPU Clock Offset +60Mhz and the Mem Clock Offset +150Mhz.
The card will then perform at:
1238Mhz Core
1625Mhz Mem
1.1750V
Temperatures etc are all okay. However heaven will crash after a couple of minutes? In the above procedure is something wrong?
Any help would be great!
1238Mhz Core
1625Mhz Mem
1.1750V
