Ok guys, I have these http://www.overclockers.co.uk/showproduct.php?prodid=WC-108-EK&groupid=962&catid=1529&subcat=1778 fittings and this http://www.overclockers.co.uk/showproduct.php?prodid=WC-048-OE&groupid=962&catid=1530&subcat=1775 tubing.
Without too much force, the tubes will fit over the barb of the fitting, and the nut/cap bit that screws on slides smoothly over the tubing as well. However, i'm finding it almost impossible to screw them down over the tube, and they will not screw in all the way as a result.
I'm just wondering if anyone has any tips for easier installation? And if not, will the fittings still be ok if not completely screwed together?
Cheers
Cheers
