Is this another faulty card?
11 Jan 2012
Bedfordshire
Problems, problems, problems. When will they stop.
Basically, got my 7950, had a bit of trouble getting it working but figured that out. Now I've come across more issues... See the video below.
Artifacting? Looks like it to me. :/ Any way to try sort this or is it just insta-RMA?
Thanks guys :)
Thats a strange bug. It looks like static from a CRT style TV, and I'm not sure about the "This video is private" message.....
This appears to be a classic PEBKAC error.
I only set my video to private because what's the need to have it public? I'm posting the link for it. :P
I'm not using a CRT monitor either, so...
The video is private, you need to make it unlisted.
Looking at the thumbnail though...that's normal for DayZ.
I had the same problem, posted a thread like you and got a response like the one i'm now giving! LOL
Change server, should be fine.
Try other games.
That was my problem, very similar if not identical. Nothing wrong with my cards, this is just DayZ, reloaded the game - changed server in the process and it all went away =)
Try other games.
If that is normal, then man that is bad :( Surely that can't be correct?
It's rare, but as far as i'm aware it's normal.
It seems to be server side though, happened to everyone i was playing with at the same time at the same place - reloading the game and changing the server seemed to have cured the problem (servers update patches at different times)
It's all post hoc, but seems to be the case as it's happened to quite a few people i play with.
Fair comments and does it still happen or is it awaiting decent patches?
That's the game graphics glitching, we're waiting on a patch to fix it, in the meantime, in game hit left shift and "-" on the numpad and type flush, that cures it temporarily.
I had that exact same thing on BFBC2 with my old GTX295's a while ago now...
Was fixed eventually after game and driver update presumably.
Thanks for all the input guys. Good to know it isn't my card - Lot of problems in a short space of time made me skeptical. Anyways! At least I know it will hopefully be fixed soonish. Also thanks dave_beast for the temp fix :D
