Ethernet 100 to 1000Mbs
6 Oct 2007
Liverpool
I am experiencing some problems in video playback on my 360...
File i am playing has a total video bitrate of 2236kbps
the video is being a little choppy in the sound but is fine on the PC, so i can assume this is a network / transfer problem.
Would changing the ethernet from 100 to 1000 straighten this out do you think, if so how is it done?
I have a Gigabyte etherport but currently set at 100mb.
Thanks
Are other files of a similar size working ok? If so then its probably the file. Also do you have a gigabite router? If so I would expect the two to automatically talk at 1000 if not you would need to upgrade the router.
2mbit over 100mbit... either you have a severe network speed issue, or it's not the network ;)
Sounds like a codec issue to me - either recode or re-download from an xbox compatible source.
As above. No way in hell you've got a video file that won't play over 100Mb.
yep i did the maths an knew this already but seen it suggested. tbh i have no idea what could cause it i will re-download the codecs on my xbox. but sometimes (PC idle) watching 30min episodes (175mb) on the xbox via PC it will mess up and the sound will jump constantly like machine gun fire is the best way to describe it not every so ofen. dunno why?
also the media extender does not like music and fast screen movment it goes very choppy (ie Big Bang Thoery Opening) works fine on dashboard player though!?
It will be the source file using codecs that aren't natively supported by the Xbox... that's all
Sorry if my assumption is incorrect... but I imagine these files aren't strictly speaking legal... if that's the case, you're entirely up to the abilities of the encoder to encode them in a format that's suitable for the Xbox.
The Xbox is very picky when it comes to codecs... that's why I built my own HTPC a while back.
HTPC + Win 7 + haali media splitter + ffdshow tryouts will play everything :)
