- 27 Jul 2005
- The Orion Spur
As they still receive their benefits I fail to see how it constitutes being unlawful or "slave labour"....the idea is to get back into work....not to be given work according to what you want to do or what you are qualified to do and nothing else. It is simply part of the criteria for claiming unemployment benefits that you periodically attend work experience for a fortnight......if you don't want to then simply do not do it, it is optional and you could always get a job yourselves....... part of the problem is not that there are no jobs, but that people are too fussy over what jobs they will do or what they see as beneath them, such as working in Poundland with a geology degree......
It's not about being fussy, if I was on the dole I would jump at the chance of having this 'work experience' if I was guaranteed a job at the end of it but very rarely does it net you a job, and in many areas there are genuinely no jobs available, down here you gets HUNDREDS of people applying for one menial position, when poundland opened here we had around 600 people applying for about 4 positions.
When I was younger and ever out of work I could always get a job the next day, you just got up early and pound the pavement, going around to local shops, hotels, super stores etc, you'd always get a job that day, but now most companies tell you that you have to apply through the job centre, it's hard to brute force your way into a job these days, and the job centre are very rarely helpful and quite often demeaning even when your genuinely looking for work.
Also elmarko1234 makes good point, how on earth are you going to be convinced that work is a good thing when your life is actually worse off during this work experience, you should be rewarded for it by being paid the market rate for the job, show the real lazy people out there that life could be much improved in fulltime employment, that you get rewarded for your efforts, not punished.
