- 27 Jul 2012
Hi,
I currently have everything at stock and I want to know if my temperatures are safe or not..
When reaching 100% cpu usage (rendering) according to task manager & speedfan my cpu temp is 49-52c and the core is 45-50c ish
are these good temps to have? they seem very hot to me!
also it is like 31-35c on idle (up to 10-20%) and I dont know if I should apply my some MX-2 as I have that un opened I dont know if its worth the time, hassle & risk to lower the temps. Personally as long as it's safe I would do it (i loved building my PC) but I have some 70% isoprypl alcohol and I don't know if thats safe to clean of the old cpu thermal crap.. could it destroy the motherboard?
and also am I meant to remove the CPU when cleaning? (i really dont want to) or should I just leave it in the motherboard and clean?
also should I purchase an arctic cooling freezer 7 pro rev 2 to lower the temps more?
