7970 stock voltage?
4 Jan 2012
Sevenoaks, Kent
Anyone know the stock voltage of these cards? I've done a google search but no one seems to actually say what it is.
I'm starting to overclock my card now, will be happy with 1125/1575 sliders maxed out. But i just want to know what voltage tends to be needed to achieve this.
sweet, my card seems to be stock at 1113mv. If i can get maxed sliders out of that, i'll be a happy bunny
Mine is 1.1125 stock and i can max out ccc sliders as well. I can get 1150 before i need to bump the voltage on the core.
I can get the memory up to 1700 without increasing the memory voltage.
Wow, mine is really low o.o ... not sure if this is good or bad :D. Depends on how it overclocks i suppose.
Doesn't that mean you can't max out the sliders then;)
1200mhz is the max.
Regards
Na thats fine i can reduce the voltage on mine at stock is 1000mhz 1174mhz but can run it on lower voltage forgot what but i can.
regards
