Iv been looking at some of the all in one cpu water cooling kits and i'm finding it hard to make the best choice.
I'm currently running
core i5 2500 k @ 4.5GHz
8GB DDDR3
OS on 60 Gb SSD
2 x 500GB HDD
ati 4850
mobo gigabyte z68ap-D3
case fractal design R4
I want to try and push my cpu past 4.5 as a lot of my work is cpu intensive and the more power the less time i have to wait for my output.
a lot of the reviews have also said they replaced the fans on the kits, is this worth doing? And if so what fans would be best. I'm also looking at getting 2 new 120mm fans to replace the stock case fans.
I have space for a 120mm rad at the back or a dual mounted in the roof.
Budget around £80 including fan replacements
Any advice would be great guys
Cheers
8GB DDDR3
OS on 60 Gb SSD
2 x 500GB HDD
ati 4850
Cheers
