fyi MADMAN:
Hmm they've changed that recently, Im pretty sure there was another option, 60mbit and 6mbit upload. Seems to have gone.
fyi MADMAN:
Downstream: 110000000 bps
Upstream: 10250000 bps
I'm guessing that's all correct?
They do power-down when inactive... don't get all that noisy.
Mine are set to always on - still whisper quiet - I do have them on stretchy stings though.
Looks like I got him beat...
Since my last windows server re-install:
Pay2Leech, hit and run or seedbox?
Dont think they are slowed down but something has been going on over the past few weeks which dont apply to their FUP.
I also find http://speedtester.bt.com/beta/speedtest-remote.jsp to be much much more reliable than any speedtest.net server for me I have never seen below 100.
A bit better, but not 100mb
Download: 57.46mbps
Upload: 9.12mbps
Ping: 17.88ms
At this time it wouldn't be congestion, those speeds are fairly close to what I would expect for being stm'd but some are also a little higher if there are no problems at your end that is a very odd problem indeed.
How are your power levels?
http://community.virginmedia.com/t5...LEVELS-amp-SNR-A-TECHNICAL-PRIMER/td-p/148068
None of the above... all traffic generated on my home Virgin connection for that screenshot. It's all scheduled for nighttime too, so as not to have a noticeably negative effect on other users.
12-13 is high tbh. it needs to be as close as 0.0 as posable.I've been looking around and my power levels did seem a bit odd compared to everyone else. On my way to work at the moment so can't post full stats, but I seem to remember my downstream power levels being around 12-13dBmv and my SNR around 40. That was for each of the 4 downstream channels the rest of the channels were 'unknown' (bit vague I know as I'm new to cable lol).
Seedbox/dedi in that case used to create buffer.
That does sound quite high ideally you will be wanting -3 to + 7 dBmv and for snr anything at 35 or above is good. So the engineer has probably not bothered to check the power levels when he did the install.
To get it fixed you are going to have to get an engineer out to sort out your power levels.
The unknown channels are just empty slots, that is probably the best way I can put it the sh can bond 8 channels down and 4 channels up but the area needs to be set for that/have the channels available for example my area is 5 down and 1 up.
