How to find out what program is using a file?
23 Dec 2009
RG8 9
I have been having this really frustrating problem recently when try to play a game of BF3. This only happens after I have finished my first game and this is the message I get when I try and rejoin -
I have scanned, reinstalled, everything. How can I find out what is using the web plugin?
Thanks.
Tried looking at event logs? Do you have any other web browsers installed that start when windows does aswell as your default?
No other browsers running. I have no idea what to look for in the event logs either.
FileMon would be your best bet although I think it's replaced by ProcessMon now?
http://technet.microsoft.com/en-us/sysinternals/bb896642.aspx
The ESN launcher program only tends to launch when you join a "party" in Battlelog - is that something you do?
I get the message as soon as I browse the server list. I can 'ok' it and try and join but I can never join as I load in forever. I actually tried that program last night, but it is hard to grab it as it only appears at the beginning of a server load then stops. It does not appear to run at any other time so I have no idea why I am getting this message.
I am actually planning on a total reformat and reinstall because it is driving me up the wall. :(
Is the process for the game still running?
FileMon is spot on but as above, i think it's called procMon now.
What happens if you load Battlelog in a different browser?
Same thing with all of them.
The game is still running along with an EA server thing. The web plugin appears to stop running as soon as you start loading but I still get this message when I have come out of a game. It appears it is only used for browsing and initially joining a server so god knows what program can be using it all the time (after the initial game).
Going to try the standalone browser detailed here tonight -
http://battlelog.battlefield.com/bf3/forum/threadview/2832654624729736565/
Process Explorer -> Find > Find Handle or DLL. It'll tell you the PID/exe of the process holding it.
Enter in part of the filename/path/whatever and click search.
Cheers but I have tried that alread but the actual file is only ever running for a few seconds so it cannot locate it to tell me what is using it.
I am totally stumped (or infected).
Well, I finally got to the bottom of the problem, though I have not got a fix. I found this great little program - http://www.emptyloop.com/unlocker/.
It has shown me that it is my damn AV (Panda) causing the problem, even though the program has been added to the exceptions on the firewall.
I have started a thread on their forums and am hoping for a permanent fix but the good news is that I can kill the process with ease when I want to join a game. :)
