3570k Overclock - Which One For Daily Setting?
12 Feb 2003
I've been having a play with overclocking my 3570k. My results are shown below:
-0.070v (LLC Level 1 = 1.170v Load) = 4.4ghz - Prime95 Blend Stable (10 Min Run) / IBT Standard Test Stable (Max Temps: 57/63/61/61) Avg: 110 GFlops
-0.060v (LLC Level 1 = 1.180v Load) = 4.4ghz - Prime95 Blend Stable (10 Min Run) / IBT Standard Test Stable (Max Temps: 58/63/62/62) Avg: 110 GFlops
-0.050v (LLC Level 1 = 1.190v Load) = 4.4ghz - Prime95 Blend Stable (10 Min Run) / IBT Standard Test Stable (Max Temps: 58/65/62/62) Avg: 110 GFlops
-0.035v (LLC Level 1 = 1.205v Load) = 4.5ghz - Prime95 Blend Stable (10 Min Run) / IBT Standard Test Stable (Max Temps: 0/0/0/0) Avg: 112 GFlops
-0.025v (LLC Level 1 = 1.215v Load) = 4.5ghz - Prime95 Blend Stable (10 Min Run) / IBT Standard Test Stable (Max Temps: 63/71/67/65) AVG: 112 GFlops
+0.005v (LLC Level 1 = 1.245v Load) = 4.6ghz - Prime95 Blend Stable (20 Min Run) / IBT Standard Test Stable (Max Temps: 67/75/70/69) Avg: 114 GFlops
+0.010v (LLC Level 1 = 1.250v Load) = 4.6ghz - Prime95 Blend Stable (20 Min Run) / IBT Standard Test Stable (Max Temps: 66/73/69/69) Avg: 114 GFlops
+0.020v (LLC Level 1 = 1.260v Load) = 4.6ghz - Prime95 Blend Stable (20 Min Run) / IBT Standard Test Stable (Max Temps: 67/75/71/68) Avg: 114 GFlops
+0.040v (LLC Level 1 = 1.280v Load) = 4.6ghz - Prime95 Blend Stable (20 Min Run) / IBT Standard Test Stable (Max Temps: 69/78/74/73) Avg: 114 GFlops
+0.060v (LLC Level 1 = 1.300v Load) = 4.7ghz - Prime95 Blend Stable (20 Min Run) / IBT Standard Test Stable (Max Temps: 72/83/76/74) Avg: 116 GFlops
+0.080v (LLC Level 1 = 1.320v Load) = 4.8ghz - Prime95 Blend Stable (20 Min Run) / IBT Standard Test Stable (Max Temps: 76/86/79/78) Avg: 118 GFlops
+0.130v (LLC Level 1 = 1.360v) = 4.9ghz - Prime95 Blend Stable (10 Min Run) / IBT Stable (Max Temp 85c)
Whilst I know that these are only short term stability tests, I can shoot for a longer term test later on.
Just really want to get your opinions on which speed you would shoot for, to use on a daily basis.
My BIOS settings are below. If you know of anything I can change that will allow me push for a lower voltage at the same speed, then i'd be happy to know :)
OC TWEAKER
Advanced Turbo 30: Disabled
Load Optimized CPU OC Setting: Disabled
Load Optimized GPU OC Setting: Disabled
**CPU CONFIGURATION**
CPU Ratio: All Core
All Core: Dependant On Speed
Host Clock Override (BCLK): 100
Spread Spectrum: Disabled
Intel Speedstep Technology: Enabled
Intel Turbo Boost Technology: Enabled
Additional Turbo Voltage: Auto
Internal PLL Overvoltage: Enabled
Long Duration Power Limit: 500
Long Duration Maintained: 1s
Short Duration Power Limit: 500
Primary Plane Current Limit: Auto
Secondary Plane Current Limit: Auto
GT Overclocking Support: Disabled
**DRAM TIMING CONFIGURATION**
DDR3-1600
**VOLTAGE CONFIGURATION**
Power Saving Mode: Disabled
CPU Voltage: Offset Mode
Offset Voltage: Dependant On Volts
CPU Load Line Calibration: Level 1
IGPU Voltage: Auto
IGPU Load Line Calibration: Auto
DRAM Voltage: Auto (1.500v)
VTT Voltage: Auto (1.053v)
VCCSA Voltage: Auto (0.928v)
ADVANCED > CPU CONFIGURATION
Active Processor Cores: All
Enhanced Halt State (C1E): Enabled
CPU C3 State Support: Enabled
CPU C6 State Support: Enabled
Package C State Support: Disabled
CPU Thermal Throttling: Enabled
No-Execute Memory Prevention: Enabled
Intel Virtualization Technology: Enabled
Hardware Prefetcher: Enabled
Adjacent Cache Line Prefetch: Enabled
Cheers,
Jim :)
I would say 4.8 as non linear relationship between vcore and speed takes a jump after this so you are nearing the limit on that cooling.
IBT kills memory controllers by the way. Use your PC to test for stability not that trash.
