- 8 Aug 2012
New member here, been slowly upgrading my gaming rig but now have a bit of a problem to solve. My girlfriend's gaming laptop has broken so instead of buying her a cheap alternative, I've decided to upgrade my PC further and use the spares to build her a new PC.
My current build is this:
Case.......Antec 900
CPU........ Intel Quad Q6600 3GHz (oc)
MoBo...... MSI P7N Diamond
GPU........ HIM HD7950 2GB
RAM....... 4x 1GB 1333Mhz
PSU........ Corsair TX 550W
HDD....... 500GB
Alt HD..... 750GB External
SSD....... OCZ 120GB Agility 3
My upgraded build will be:
Case...... Antec 900
CPU........ i5 3570K (ivy) 3.4GHz (of course I will OC this
MoBo...... Gigabyte Ga-Z77M-D3H
RAM....... 2x 4GB 1600Mhz (not sure which type to get, everyone tells me ripjaws)
HDD....... 500GB
This will free up my old MoBo, CPU, GPU and RAM which will be going into her new (spares) build. She has a monitor / accessories.
I figure she'll only need a case, fan, PSU and hard drive (she has an old one but it is really old, so i'm not sure how much use it'll be) - perhaps a CD / DVD drive (but I might give her mine as I don't use it)
Here are my questions:
1: Is my new build solid / will everything play nice (was a little worried about PSU)?
2: Is there anything that should be upgraded (same / very similar price?) - motherboards confuse me
3: What would you suggest I buy to complete her build - this is case, psu, hard drive, fan, maybe dvd drive. (I'm thinking £70 - £100, but as cheap as possible, I'm a nice guy, right?)
Her build should be...?
Case.......[Insert cheap & cheerful case here]
GPU........ 2x Nvidia 9600gt (SLi)
PSU........ [Insert PSU here, included with case maybe?]
HDD....... [Insert cheap HD here]
FAN........[Insert cheap CPU cooler here]
Anyway, any help would be greatly appreciated and I do hope I haven't missed anything out. Hopefully once I learn a bit more I'll be able to help out here too.
Thanks!
#Quick Edit: My budget is £350, i'll upgrade more if it makes sense but will spend no more than £400.
HDD....... 500GB
HDD....... 500GB
Thanks!
