Permabanned
- 22 Aug 2004
Ok so since im upgrading thought id post some info, and since my 7850 is faulty ill post more results using a 7950 tomorrow
The purpose hopefully is to assist others in the decision to upgrade to i7 from earlier non 'i' cpus, glad i did!
Q6600 3.0Ghz 4gig hyperX ddr2 @ 800mhz Asus P5QL-Pro
3dmark01 stock 30630
3dmark 03 stock 69680
3dmark06 stock 12502
3dmark vantage stock P13168 16946/7890
3dmark2011 stock P4282 5079/2953/2855
Heaven Stock 1919
Upgrade (i7 3770k auto OC seems to like 4.2ghz under load - 8gig gskill ripjaws 1600mhz Asus P8Z88-V Pro)
3dmark01 stock 72309
3dmark 03 stock 108573
3dmark06 stock 29132
3dmark vantage stock 23530 22040/29515
3dmark2011 stock P6008 5596/9915/5784
Heaven Stock 1772 42 134.9 70.3 av
Interesting results, the vast increase in CPU power shows in all tests up to 3DM2011 where it balances but CPU turns out 9k while gpu can only cope with 5.7k will be interested to see what changes with the 7950 tomorrow. Dont know why Heaven is lower it crashed 4/5 times (because of the faulty GPU) so will write it off for now,
All in all couldnt recommend the upgrade more! Also my SSD running now at 6Gb/s is insane, general performance through the roof, thought an i73770k was overkill versus a 2500k i5 but very glad i splashed out.
The purpose hopefully is to assist others in the decision to upgrade to i7 from earlier non 'i' cpus, glad i did!Q6600 3.0Ghz 4gig hyperX ddr2 @ 800mhz Asus P5QL-Pro
Heaven Stock 1919
