don't forget, since everything these days is multi-platform, you're going to be fine at least until the xbox720/ ps4 are released. which won't be for a couple years yet.
Should I be able to max out all games @ 1080p with a 3570K and a GTX 670?
is it future proof for 1-2 years?
I thought the xbox720/ps4 are using older hardware comparing to what we use today so how does that make games more demanding for us pc gamers?
The games I would like to play are Battlefield 3, Counter Strike: Global Offensive and ARMA 3.
The PC port always needs higher-spec hardware than the console version.
You can really optimise code for consoles in a way you can't for PCs. Thus PCs need more grunt to run the same game.
The point of my post, however, is that going forwards, the PC as a platform is heavily tied to the consoles. So you won't really benefit from top of the range hardware if you're limited to 1080p.
People using 670s are using high-res screens or multi-display setups.
The next consoles are using AMD CPU's and GPU's. The hardware they are using is similar to hardware in a gaming pc so future consoles will be easier and hopefully better performing when ported compared to current consoles. Current consoles are extremely heavy on the CPU IIRC and barely use GPU.
Check up on steam games being ported to linux too, big improvements in fps by ditching dx
it will take sometime.
rumour has it Valve is building a console based on linux.
You know some games run faster in wine under linux than on win.
