Ahh, i remember seeing your build on the other forum you mentioned StonedRaider. Very nice.
Ahh, what's your BF3 / DayZ name then?
I don't want it to be "stealthy"...I put freaking red led fans in it.
Once I have my WC loop in there at end of the month I will also change the window for one without holes. If you want i'll do a build log of that as well. It's very easy. Just unscrew panel, use panel as size guide (but increase by 1cm) on some acrylic. Cut out and drill holes...Voila...He says, not having done it yet. But really. Is easy.
Joe, you really don't want to drill holes like the current panel has since acrylic likes to easily snap when you drill it, a better idea is using double sided foam tape to stick it down![]()
The case is epic!![]()
What's a mid plate![]()
Ahhhhhhhhhh cheers acme...
Upgrade path is.....
1. Watercooling loop
2. GPU block + extra Rad
3. New Piledriver CPU
Yes I know I should save up and get ROG intel but this handles BF3 and Premiere pro easily so why would I bother...
Oh now I know that Intel is better..and just works.
I have a special place in my heart for broken things
Photo not showing :'(
ehh... You could easily mod some clear acrylic in there.
just got my new c70 last weekend! looks amazing! Here is my post showing the pictures.
http://forums.overclockers.co.uk/showthread.php?t=18431787
let me know what you think acme15![]()
