Spec me for £500 to £600
5 Aug 2012
hi i know my way around computers slightly but not confident in buying the correct parts for my budget. I'm looking to build a desktop which runs windows 7 with office. I would also like to be able to play games like tera online and guild wars 2 on high settings with a decent frame rate......(not sure if possible with my budget).
i only need the tower, i dont need monitor keyboard etc.
any input would be great thanks.
thankyou for both of your inputs but personally i would rather go with that slightly cheaper option so the radeon 6850 seems like the better choice as it only just loses in competition against the 460 =]
Just no on that HDD, and why the more expensive DVD-RW and why not Ivy?
Ive chosen the cheaper DVD-RW
Didn't see ivy was on offer yeh go ivy its only £7 more still in budget.
And the 500GB HDD because the budget doesnt afford a 1TB. Ive put a 550ti 448 into teh build which is loads better than a 6850.
