- 25 Mar 2004
- Fareham
Note I put "review" into quotes, this is not an official review
So I recently went from an old style Cosmos case to the Corsair 650D. I wanted something that did not have handles (I don't need to move it much) and also I wanted to finally put the sides back on the case without my PC overheating.
Corsair 650D seemed to fit the bill quite well. Big old 200mm fans for more airflow/less noise.
Good Points:
Bad Points:
These might be unique to me, I've raised them to Corsair:
If I plug a drive into the hot-swap bay, it crashes Windows without fail. If a drive is plugged in before I power on the machine it does work.
My Kindle won't work properly on the front panel USB 2.0 port. It works fine when plugged into the back of the computer though.
Summary
A good case if you don't need to replace the front fan or move the hard drive cages. If you do I would not recommend this case without serious looking at alternatives.
Corsair could fix these problems pretty easily by putting in a 200mm fan that was actually silent. They could also let you screw the cage into the left slot using holes on the bottom instead of screws on the left side.
Let down by some design flaws that even I could see needed resolving. 6/10.
Good Points:
- Solidly built, case seems to be using good quality materials. No dodgy sharp edges to be found.
- The Built-in hot-swap bay is a really useful feature. Let me plug in hard drives without needing to get a separate drive bay? yes please!
- Comes in black. everyone likes black. Goes with anything.
- Built in fan controller. Easily accessible (it's in the same section as the hot-swap bay).
- Sides come off nice and easy.
- The front fan grill clips into place and can be easily removed for cleaning.
- Case is generally not too large, a good size. Probably not good for water cooling though.
- You can get at the back of the CPU to allow easier installation of a new CPU cooler without removing the entire motherboard.
- Cable Management is easy with lots of holes to put cables through etc.
Bad Points:
- The front 200mm fan seems exceptionally noisy, even on the lowest setting on the fan controller.
- To replace the front fan with something else, it either needs to be 20mm thick, or you need to "mod" the case and remove the front fan grill. Picture to demonstrate taken by Robbie Khan (mrk on these forums) http://i.imgur.com/Mb329.jpg
- If you decide to replace the front fan with one which is >20mm thick, you also need to move the drive cages to the left.
- If you move the drive cages to the left, you can generally only fit one in. The second one will be blocked if you have a large GPU. This is a problem for me because I have 3 3.5" drives and 2 2.5" drives, and you can only fit 3 drives into one cage.
- If you have moved the drive cage to the left, you can't remove the lowest hard drive from the bottom cage without removing the entire cage.
- The drive cage is screwed in with two screws to the left at the front and back, next to the power supply. If you have a large PSU, you will need to remove that before you can take out the drive cage.
- It's very hard to put the power cables in to the drives without them putting pressure on the side of the case, meaning you can't close the case properly. Even now mine is not exactly plush.
Summary
