hey guys
25 Jul 2011
hey guys im having problem with my laptop
when i start it up it goes to windows recovery mode and freezes.
i can access my bios and have reset it to default setting still no use
tried booting win 7 cd and freezes when i press a button and the press any key to continue....
anyone any ideas in how i could fix this problem?
i took the hard drive out and reinstalled when i put it back in it worked for like 20mins then i shut the comp down and the problem happend again
sorry for putting in wrong forun ^^ but the hdd was working fine on my computer? but then when i placed on the laptop boom stopped working
Sounds like an issue with the RAM to be honest, if you have a faulty chip you'll get problems like this.
If you can, try the laptop with one stick, see if it still has issues, if it does, try it with the other stick (assuming it has two sticks of RAM). Also try each stick individually in slot two instead of slot one (after trying in slot one).
just plugged into my computer and ran fine [deleted resotration data ect]
and now plugged into laptop works fine
however if u shut it down wrong or just turn pc off it goes into windows recovery mode [this is when it freezes and stops responding only] wierd eh?
still have the problem usb legacy support is enabled tried plugging keyboard in and it just goes unresponsive at that ceratin point ^^ it works but when it gets to restore screen thats when the computer has problems
