It seems developers are paid to make games struggle on even expensive hardware so users go out and buy the top of the range stuff. Bad console ports and unoptimized game engines are a **** take from developers tbh. They should fix this stuff before release.
Think it will be playable with a 3570k + GTX 670?
Yes who are they going to sell it to if it did not. cray gamer numbers are limited unfortunately
Of course, anything with a i5/phenom x4 and a 5770 will run it.
What sort of hardware would someone need to max it completely at 720p/1080p?
^^The irony is the game is made by a studio that develops primarily for PC, so their games certainly aren't "bad console ports".
Past experience tells us you will need a monster CPU for this game but to be fair by the time it comes out most serious PC gamers will probably have a quadcore, the only ones who might struggle are those who have a slow clockspeed at stock and don't overclock. Of course, to get genuinely top performance (rather than merely OK) I'd suggest you'll want to be running Sandy/Ivy in excess of 5ghz.
Thing is this is for PC, and it has a right to use so much power if you see what the game needs to calculate while playing.
