My new PC!, Thanks OC uk
30 Jul 2012
Afternoon all,
Just wanted to say a big thanks to Overclockers UK for all the help specially 5UB, NathWraith and Dan from the Build Team. My over all experience with Overclockers has been great from all the help I received on the forums down to the help from HQ. Only a small mishap with the shipping but was keep well informed and treated with the highest regards.
Thanks again for converting this old Apple Mac user back to PC :P
Build
System Specification
- Case: Consair Vengance c70 Green - Windowed
- Power Supply: OCZ ZS 650W PSU
- CPU: Intel Core i5 3570K 3.40GHz Overclocked to 4.60GHz
- Motherboard: Gigabyte Z77X-D3H (Socket 1155) DDR3 Motherboard
- RAM: 8GB (2x4GB) DDR3 1600MHz C9 Dual Channel
- MIS Twin Frozr GeForce GTX 680 2048MB GDDR5 PCI-Express Graphics Card
- Hard Drive: 1TB HDD Sata III with 64mb Cache
- 180GB Intel SSD
- Sound: 7.1 Channel Sound (On-Board)
- Optical Drive: LG DVD+/-RW SATA Drive
Watercooling Specification
- Radiator: XSPC EX240 Dual Radiator
- Pump/Reservoir: XSPC Dual Bay D5 Reservoir/pump
- CPU Block: XSPC RayStorm Intel CPU Waterblock
- Fittings: x6 XSPC G1/4" to 7/16" Compression Fittings
- Tubing: x2 XSPC Clear 7/16" Tubing - 1m (Total 2 metres)
Sorry one of the pictures is sideways!?
