After a break of 2-3 weeks, I decided to take it
very easy on the old Leg and shoulders. Well almost. I did climbing & bouldering on Sunday all day and will be doing climbing and bouldering this evening :-/
The order is a bit screwed because I couldn't initially get on the squat rack. A couple guys were using the squat rack oly bar for T-bar rows...when there were 2-3 oly bars available around the other side
and I wasn't going to carry a 20kg bar over. Then they wanted to do BoRs using this very same bar; again, these could have been done around the other side
BB SLDLs: 60kg x5, 60kg x5, 70kg x5, 80kg x5, 90kg x5;
BB Calf Raises: 60kg x5, 60kg x5, 70kg x5, 70kg x5, 80kg x5;
DB Step-up lunges: 2x10kg x5 x5;
DB Shoulder Press: 2x10kg x12, 2x10kg x12, 2x10kg x12;
BB Squats: 70kg x5, 70kg x5, 80kg x5, 80kg x5, 90kg x5;
DB Front & Side raises: 2x6kg x12, 2x4kg x12, 2x4kg x12;
Shrugs: 2x15kg x12 for 3 sets.
DB Goblet Squats: 30kg x5, 36kg x5, 40kg x5, 40kg x5, 46kg x5;
I intentionally lifted a higher weight each set where possible because of the break I had. It also gives me an idea of what I can do and where I can go next time without causing injury by jumping straight in.
David
