whats your thoughts on the NZXT switch 810?
22 Nov 2010
Kettering
Hey guys,
Whats your opinions on the NZXT switch 810?
Ive read that it can hold up to 480 rad up top and a 240 at the bottom, as well as the adjustable fans on tje HDD cages.
Watercooling may be a option later down the line, but it will be housing 2x 7970's in crossfire and a soundcard and all the other components.
Im using a cm690 ii lite atm so looking for a case that i can buy and keep for a long time and have so many different routes to choose from when i want to.
Whats the pros and cons with this case?
It's a great case, read somewhere that if you're going to use a optical bay it can take up 20% of the space used for a top-fan.
But that's not too much of a issue.
Yeh i was thinking the same about colours, i like the built in card reader and the piviot fans for the hot gpus (higher overclocks with this case i would have thought)
Really great for the money, I have the gloss black one and if you don't have dirty fingers it does look good. See link in sig for some pictures of my build.
Fantastic feature wise, and knocks pretty much everything in that price range out of the water feature wise.
Not bad for air either... I just couldn't ever get over the look/tackyness of it all....
kd
Fantastic features and that, just incredibly ugly. Looks like the beige cases I had in about 2000/2001
I'm not a fan of the looks, its a bit...I don't know how to put it. I like more classic looking cases but the Switch is a bit all over the place to look at.
