Alternator pulley hot
23 Sep 2006
Wiltshire
Hello chaps,
The aux belt on my girlfriends car started squealing horribly the other day, I accidentally touched the alternator pulley whilst having a look and it was quite hot, too hot to touch for more than a second or two and the engine had only been run for 20 seconds.
The pulley does spin when the engine is running, I'm ordering a new belt and will check it all properly at the weekend.
Is this normal or is the pulley starting to seize?
Thanks.
What car is it, does the pulley have a clutch?
It's a 2001 civic 1.6, a mk7 I believe.
I've no idea if the pulley has a clutch, though from some googling of the terms nothing comes up.
If the bearings have had it then I assume it's new alternator time?
