- 11 Dec 2005
- Cheshire
Today we have the mental Prolimatech MK-26 VGA cooler available for pre-order, now is the chance to get the finest VGA cooler in the world. Quiet, stylish and it delivers excellent operating temps. What more could you want?!
Prolimatech MK-26 Multi VGA Cooler @ £51.99 inc VAT
The Prolimatech Mk-26 is meticulously crafted. Designed and engineered for maximum cooling capabilities and efficiency. Compatible with most popular graphics cards, the MK-26 provides a quieter alternative to other inferior VGA coolers.
Technical Details:
- Dimensions: 257.1 x 47.1 x 146 mm (W x H x D)
- Material: Nickel-Copper (base plate, heat pipes), nickel-plated aluminum (blades)
- Weight (without fan): 590g
- Heatpipes: 6 x 6 mm Ø
- Fan (optional): 2x 140/120 mm
- Compatibility:
AMD Radeon (reference design):
HD 3850/3870
HD 4830/4850/4870/4890
HD 5830/5850/5870
HD 6790/6850/6870/6950/6970
HD 7750/7770/7850/7870/7950/7970
NVIDIA GeForce (reference design)
7800/7900 GS / GT / GTX / GTX512
8800 GS / GT / GTS (G80) / GTS (G92) / GTS512 (G92) / GTX / Ultra
9500/9600/9800 GSO / GT / GTX / GTX +
GT 130 (OEM)
GTS 150 (OEM) / GTS 240 (OEM) / 250/450
GTX 460 SE / 460/480
GTX 550 Ti / 560 SE / 560/560 Ti / 570/580/670/680
- Contents:
High and flat RAM cooler
voltage transformer cooler block
2 x 2 brackets for mounting two fans
PWM splitter cable to connect the two PWM fans at the VGA connector
2-g tube Prolimatech thermal compound PK-3
Needed more space between the motherboard and case side panel, depending on the VGA Type:
ATI Radeon HD 7970: 175 mm
Only £51.99 inc VAT.
ORDER NOW
Technical Details:
- Compatibility:
HD 3850/3870
HD 5830/5850/5870
GT 130 (OEM)
- Contents:
ORDER NOW
