5D mkii forces PC upgrade!
14 Mar 2005
Here and There...
I know this probably belongs in general hardware but I can't quite bring myself to post it their and am labouring under the illusion that I will get more specific advice here!
I got a 5D mkii a few weeks back and it has caused my ageing PC (AMD Opteron 170 with 2GB of RAM) to sulk massively it really can't handle the file sizes and processing images is just too painfull so it is upgrade o'clock.
I only use the PC for photo editing and a bit of surfing etc so I really don't need a gaming beast and as with all electronics I'm happy to go second hand. So what would you guys recomend as a processor RAM and mobo combination for sub £250 which can do the job?
I'll then treat myself to a new copy of windows 7 or 8 as a seperate purchase.
I would recommended the same as above, think if your processing allot of images you would benefit from the i7 possibly, but for the extra price it might not be worth it.
Mainly your bottleneck would be ram also, So would advice 8gig+ easily would go higher if you can afford it.
I use a macbook air (i5 4gb ram 128gb SSD) and it also doesn't struggle with the 5D mk ii files at all.
i5, Z68 or Z77 mobo, at least 8Gb ram, and a nice zippy 128Gb SSD will make light work of raw files.
I wouldn't waste the money getting i7 as the extra threads just won't be used :)
Don't anyone supposedly anyone know to an issue I'm having with in Lightroom.
When I'm playing a youtube song in the background Opera / IE / Firefox. When I'm editing mass images on LR (4-6) pictures at a time, when I start adjusting the sliders like temp / exposure and etc. The song in the background stutters until I stop.
Running Ivybridge I5 3570K (i think) 8GB Ram, OS and Programs on SSD and pictures on a RAID 0 set up on my computer. Thoughts?
I've noticed the same - i3, 12GB RAM, SSD etc. Could possibly be an issue with Flash. I might test a few things later on and see if I can get to the root of the problem.
i build a server pc that runs a i5 quad, 4gb ram and a full tower case for around £200. add in a hdd and psu and should come to around £300 if your budget can stretch that far.
all quality components.
do not skimp on a psu though. spend miminum around £50 on a well established brand like seasonic, corsair, enermax etc
Also get the same issues with mine on an overclocked i7 with 8GB of RAM so it seems it's just the software? Tends to be when its opening RAW files or getting more detail as I zoom in to check details.
I have my Aperture library on a RAID 0 for speed, however it gets backed up to three other places, so its not an issue if it goes down.
