Matt my 5ghz 2500k is fine with my 7970! Gpu is always 99% on bf3! Try upping ya clock speed a bit!
And before anyone asks, I'm using hdmi sound from a 7970 as my amp (Onkyo 609) has no analog input for 5.1 and hdmi sound is better quality than via a digital cable that compresses the audio.Not sure, but you used to be able to use the Realtek HDMI ATI drivers. Tried those?
My 7950 stays at 100 load on Gpu-z I have my i5 2500k OC to 4.4. will give these a run tomorrow.
My best score with heaven is 1770 with 12.4
1080p 4xAA
High
High
trilinear
4x
enabled
enabled
enabled
tess Normal
Fps 70.3
min 13.7
max 146.8
Gpu OC 1005/1500 1.037v
Anyone whilling to post score with them settings for me with a 7950?
Just did a quick run with my i7 @ 4.4GHz and same 7950 clocks as yours.
Remember our systems are not identical..
http://i.imgur.com/61A29.jpg
FPS 69.0
Scores 1739
Min 35.9
Max 154.4
Possibly better min and max fps for u though im using an SSD and im not sure if u are![]()
For those of you that are getting audio issues after 12.4
well install 12.4 and then install 12.8, but do a custom install and don't install the audio drivers that come with 12.8
