I'm new to Apple and Mac's.... Only have an iPad2...
Tempted to step up to an Air, 13"....
Apple hardware just seems to be the nicest.
Thinking of this spec.... I7, 256 SSD, 8gig RAM. I believe you have to spec the amount of RAM when buying as you can't add more later.
Will it work with the latest 128GB SD memory cards ?
I may want to dual boot it with Windows..... (waiting to be flamed
Will install Photoshop Elements.
Can I plug my Canon I9900 A3 printer into it ?
Do they support flash websites unlike the iPad
Will any external USB DVD/BD drive plug in and work... Or needs to be an Apple drive.
Can you get something like EAC for ripping music files to FLAC ?
Is worth getting the latest 2012 spec, or pick up the previous 2011 spec I see being sold off cheaper ?
Anything else I should know........
)Will install Photoshop Elements.
