Ive used these before, and since a ton of people have asked if i had my teeth whitened, 100% recommend them
My teeth are all healthy and fine, but they are naturally yellow(I've been told) though my wisdom teeth are coming through and they are pure white! I'm guessing years of drinking tea and only brushing once a day has caused stains? Will these do anything?
Im not sure, but i was discussing this with as many people as i could in the 30 mins i was umming and arrring to buy them and one said they can make your teeth very sensative.. so might not be so good.
Yes, get the advanced vivid or the one above that. The cheaper ones dont make much of a difference.
how big are the strips, sorry to ask im sure i could find it if i looked around, are they chewing gum size ? i think id need them that big !
in mm... how wide too they say fold them over the tooth. i want to make sure the top bits are white too.. does that make sense?
edit: further reading and reviews all complain they are too small to fully cover the teeth... thats disappointing to say the least... i guess ill use 2 sets at a time :O
Mine arrived today and just using it. After first 10 minutes I got 3-5 sharp strikes through one of my bottom teeth. Slightly worrying considering I've had sensitive issues in the past and its cleared up now. Hope this doesn't bring it back.
