Try verifying files usually fixes stuff like that....i get an odd white box too before game loads up but then vanishes quickly and works.
Says it's all OK
Might just delete local content and let it re-download overnight....
an yone else gettting disk IO failure?
Ouch this is without HD texture pack installed think its time for upgrade the 460 showing its age.![]()
You have Vsync enabled in that benchmark which won't be helping, but it's a faff to change settings atm due to a bug the patch has caused.
yep i cant change any graphics options either.
played a little bit and im enjoying it so far, whats with the weird shaking camera while driving?
Sleeping Dogs version 1.3 update tonight!
In anticipation of the European launch of Sleeping Dogs and in response to some of the feedback generated by the PC gamers on the forum we’ve prepared a patch that aims to improve some PC-specific features as well as fix some bugs that have been reported by the community. The full list of changes is below:
Improvements & Bug Fixes
• Fixed several bugs where NPCs would not path through doors properly – this corrects the issue where Naz stops running in the first mission of the game
• Added HD Textures for UI screens (only available with the free HD Texture Pack DLC installed)
• Improvements made to reduce the frequency of erroneous “don’t lose your target” warnings in missions where you are chasing an NPC
• Significant improvements to mouse support on various options screens
• New Keyboard/Mouse option which makes the keyboard & mouse the only input devices even if a controller is connected
• Several minor text bugs corrected
• Fixed an issue where mouse clicks would sometimes be ignored in the UI
• Fixed the keyboard and mouse camera controls in the Phone Tracing minigame
