Best budget PSU for £40 or less?
1 Nov 2004
Whats currently the best Best budget PSU for £40 or less?
Needs at least 4 sata plugs and silent.
I keep coming across the 430W Corsair Builder Series V2 and the Coolermaster GX-Lite 500W being mentioned a lot but some say they are silent and others say they are both noisey?
Thanks
Its' for a budget Intel G540 desktop that will be used just for general surfing and media playback.
The one Menty mentioned does look awsome being a Seasonic.
400w is plenty as it will never be used for gaming.
*edit*
Seem to be a lot of reports at Google saying the Antec High Current Gamer 400W has fan rattle which seems odd for a Seasonic.
*edit*
A decent branded 400W PSU is fine for gaming, but just best not to use with graphic cards that require more than a single PCI-E 6pin.
